Car engine stuttering problem
Old Dec 28, 2010 | 12:52 AM
clinthammer's Avatar
My car has had this issue for a few months now. At times when I am stopped at a signal (not when in P but only in D gear) and the revs are idle between 600 - 900, the car stutters a bit. If jerks lightly at these rpms and if I give it some gas or put in N it seems fine.
Today morning the temp showed 15C and although I warmed up my car for a good 5-10 minutes (which I do always), it stuttered a bit at the first signal. At the next signal it was a bit more longer the stuttering.
However, despite the stuttering/jerking, the car never seemed (touch wood) like it would shut off or anything. My car has always been serviced regularly with no engine problems at the dealer from the day I bought it.
Could it be the cold weather? Could it be my uprev tune?
NOte that after the second signal, I drove the car at about 4000-5000 rpm to warm it up some more and at the next few signals it seemed fine. I personally feel its the engine/fuel being cold cuz after the first or second light it is fine.
What do you guys think? Any help/input is appreciated.
Old Dec 28, 2010 | 05:21 AM
4D05G35's Avatar
How many miles and have you had a full tune-up? Sounds like a tune-up/spark issue to me.
Old Dec 28, 2010 | 05:23 AM
116,000 kms. I had a tune up for my mods only.
Car always serviced at dealer and spark plugs changed at 100,000 kms.
My friends here locally say it could be throttle body that needs cleaning. One of them has a 05 sedan and cleaned his TB when he had the same issue.
Old Dec 28, 2010 | 11:28 AM
maciejk's Avatar
ya stop warming up your engine its bad this way, google proper warm up procedure, 30 secs in any weather then slowly drive off until warmed up
Old Dec 28, 2010 | 11:57 AM
Mustang5L5's Avatar
15C isn't really cold. That's 60F. That's turn the key and drive weather. Shouldn't really affect anything. 15C is when i roll my windows down and open my sunroof. 5-10 min warmup is unnecessary at this temp unless you really want the heat working before you get in the car.
For comparison, it was -8C this AM. I started my car, put my seatbelt , adjusted radio and heat, etc and then slowly drove off. Ran normally.
Is your CEL on? Could be any number of things from bad fuel, to a failing COP, etc.
Old Dec 28, 2010 | 12:29 PM
nope no CEL at all.
Old Dec 28, 2010 | 01:27 PM
Bassman's Avatar
Dirty injectors? Ever run cleaner through your tank?
Old Dec 28, 2010 | 01:45 PM
Mustang5L5's Avatar
You can start with some routine maintainence then. New air filter, injector cleaner, possibly even go as far as new spark plugs.
How dusty is the area you live? You could take the MAF out and spray some electronics spray on the element and try to clean it. A throttle body cleaning might help as well
Basically with no code and no obvious mechanical issue you should start from square 1
Old Dec 28, 2010 | 10:23 PM
I honestly do not need routine maintenance. The dealer services my car religiously ever 5000 kms since day 1 when I bought it. Spark plugs changed at 100k, air filter (JWT) cleaned every 5000 kms and engine flushing done at about 105,000 kms (currently 116000) kms.
I've had this problem since 100,000 kms and only thing not done was TB cleaning so I will get that done soon
Old Jan 17, 2011 | 11:31 AM
Dynasty47x's Avatar
You could check the gasket for your manifold it might be a little shurnken and letting in cold air until the car warms up and the gasket seals the gaps. I had the same problem with my maxima it only happens when it's cold outside.I f your always in cold weather I would get it changed, probably a good time to upgrade to a 5/16 spacer should resolve your issue.
Old Jan 17, 2011 | 12:34 PM
am already running MD 5/16 spacer and I live in middle east.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
wojowojo16
Jul 27, 2015 09:57 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
