UPDATE FD 3.54 ....Awesome!!!!..
Old May 15, 2011 | 05:27 PM
  #76
4D05G35's Avatar
I will do that, as of right now (10 miles driven) I'm loving it.
Old Jun 4, 2011 | 07:35 PM
  #77
JaE35's Avatar
Moderator
G35 Sedan
I'm assuming it's going to be pretty hard to find a 3.7 for the right price...is there a big difference in the 3.5? Currently have the 3.3
Old Jun 4, 2011 | 08:06 PM
  #78
4D05G35's Avatar
Do you currently have a VLSD?
The change in gearing was a nice little bump, but gaining the VLSD was just as nice. If you can find a 3.7 w/VLSD then I would go that route. But IMO the 3.5 was well worth the money spent.
Old Jun 4, 2011 | 08:08 PM
  #79
4D05G35's Avatar
I'm not sure how much the 3.7's run, but I ended up spending about $200 including new fluids. So that is something to also factor in.
Old Jun 4, 2011 | 08:14 PM
  #80
JaE35's Avatar
Moderator
G35 Sedan
I'm currently stock in this area so whatever comes factory, i think you answered my question. Was just wondering real world performance differences. I was under the assumption they all came with VLSD
Old Jun 4, 2011 | 08:28 PM
  #81
JaE35's Avatar
Moderator
G35 Sedan
that's what i'm talkin about what car did you get yours from? *edit, found it on infiniti help
Old Jun 4, 2011 | 09:47 PM
  #82
4D05G35's Avatar
I am not 100% sure but I think the only sedans that came with a VLSD were the 6MT's. I could be wrong. I know that they all dont come with a VLSD, and I know that my 05 5AT didnt come with one. .
Old Jun 4, 2011 | 10:41 PM
  #83
JaE35's Avatar
Moderator
G35 Sedan
So is it not correct to assume 6mt g35's come with vlsd?
Old Jun 5, 2011 | 01:54 AM
  #84
4D05G35's Avatar
I pulled this
"All G sedan 6MTs from 04 to 06.
All G 6MT coupes 03 to 07.
All 350Z 6MTs with the Touring or Track package from 03 to 08."
From here,
https://g35driver.com/forums/drivetr...r-gearing.html
Old Jun 6, 2011 | 11:51 AM
  #85
NotsafeG35's Avatar
Originally Posted by DaveB
Agree to disagree
I've got a set of 23.5" tall drag radials which give my car an effective gear ratio of around a 3.55 (car had the 3.34 gear set at the time). On same day at the strip, I did four runs with the 26.3" tall OEM 17s and 3 runs with the DRs, which were also 15lbs lighter each than the 17s. The car did consistent higher 14.4s and lower 14.5s@97-98mph with low 2.2 60 foots with the 17s. With the DRs, the car did consistent lower 14.5s at higher 96mph with mid 2.1 60 foots. It never could break into the 14.4s. The car was quicker off the line, in the 1/8 mile, just the same as the 17s at the 1000' mark, but the killer was the forced shift to 4th about 150 feet short of the finish. It crippled both ET and MPH.
Years ago, my friend had a 90 LX 5.0 nothback 5MT. It was basically stock except for a catback, pullies, and hacked airbox. It came stock with 3.27s. It did 14.0s@98mph with the stock gears. He then added 3.73s. The car totally woke up and felt awesome in 1st, 2nd, and 3rd. After that, acceleration tailed off. With the 3.73s it did 14.2s@97. 60 foots were better, it was quicker in the 1/8th, but since he had to run through a lot of 4th, the car slowed down. The 3.73s were just too much gear for that 5.0 that peaked at around 5000rpms. No problem though, he added a heavier breathing cam, intake manifold, valvetrain stuff which extended power to around 6500rpms and it was doing mid 13s. With extra breathing allowed the motor to fully use the deeper gears.
The only reason I went with the 3.54s in my G was because I wanted snappier daily driving, more gearing would help in the auto-x (sub 65mph racing), and I wanted the LSD (huge help in the auto-x). I haven't been to the strip in 2 years. I may try it again with my DRs which would effective gear the car to a 3.75.
Some cars come from the factory woefully undergeared. The 98-00 Cobras are prime examples. They come with 3.27s, but the motor makes good power in the mid to upper rpms and revs out 7000rpms. The long gear don't allow the motor to get into the meat of it's powerband quickly nor fully exploit the powerband. Adding a 4.X series gear will easily shed .3 seconds and add 1-2mph in the 1/4 mile. The G and Z aren't those cars, at least with stock cammed VQs. Nissan did a pretty good job gearing these cars for strong acceleration while trying to maintain some MPG sanity. There aren't many other V6 sport luxury sedan/coupes out there that perform as with just 260-280hp. Since these cars are already decently geared stock, they don't make significant gains when adding deeper gears. They definitely feel quicker since there's more torque multiplication therefore seat of the pants acceleration 'feels' more impressive. Put that feel under the clock and you'll see that the two don't necessarily agree. My friend's 5.0 felt downright brutal in every gear. It felt far quicker than 14.2s. All that torque multiplication mislead the mind.
I'll come into this conversation late, however I had a similar experience. Good call out though!
A friend of mine has a Fox Notch 5.0 with just intake, full exhaust, and 3.73s, and we've entered contests of speed before. From a 40 2nd gear roll on we were pretty even until I got into fourth and I started running away like it was a different car. Obviously the gear set would be good for the 1/8th, but the stock heads and cam won't huff enough air up top. With the set up I had when we made the pull, I trapped 102. He just recently got a mild cam and intake mani so I'm curious to how things would work out now.
I've got the video of it somewhere, but its night time.
Old Jun 6, 2011 | 09:51 PM
  #86
DaveB's Avatar
That Stang will be like a different car with a cam and manifold.
DEMoLITIoN
Interior
47
Oct 6, 2018 10:44 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
