VDC OFF, SLIP lights on and speedo not working
Old Jan 13, 2011 | 07:52 PM
MM_G3520's Avatar
Originally Posted by VincenzG35
Really weird I wasn't even looking this up it happend to me out of nowhere and went off in an hour I first went to the store and the BRAKE light came off when I started it back up then I stoped at the bank and when I got back in my car VDC OFF and SLIP turned off as well the only common thing I see between all those mentioned this is we have double dins/ head units maybe a relation? Either way its happining on models 03-06 and personally I think its liquid or the cold the day it happend it snowed about a foot and an earlier post mentioned a puddle ect...
Wait, so you only get the BRAKE, SLIP, and VDC lights, and it starts with only the BRAKE light? You either need to change your pads, or add more brake fluid. You could be right on the threshold when the fluid is warm, but low enough to trigger a light when it's cold out. Brake fluid expands by about 15% from cold to hot. As I mentioned earlier in the thread, mine just did the same thing, and I added a little brake fluid. The lights haven't come on since!
Old Jan 20, 2011 | 08:07 AM
MeNmyG35's Avatar
Originally Posted by tstrayer
I installed new rear rotors and pads today in hopes that the problem would go away.
It didn't.
Does anyone have any ideas?
I'm not so concerned with the slip and vdc off lights as i am as with the speedometer not working.
I will be calling infiniti USA and a dealer in regards to the TSB about this issue in hopes they can fix it. I have not yet been toa dealer as they are all far away so i am hoping they can provide assistance over the phone before i drive all the way there.
try resesting diagnostics by turning key to on (engine off) then before air bag light stops blinking turn off repeat that like 5x that should fix it i had the same problem
Old Jan 21, 2011 | 12:39 AM
totopo's Avatar
Happened to me before when my battery terminal was loose. bump or turn would sometimes loosen it up enough to make everything go crazy.
Old Mar 6, 2011 | 04:45 AM
sch4400's Avatar
Happened to me one weeks ago when my motor got little damage.
Old Feb 25, 2014 | 08:30 PM
20G35sedan03's Avatar
Im haveing similar problems with the lights coming on and speedo droping to zero the car starts down shifting but also my cd player(aftermarket) and my heat/ac diplay goes out and comes back on. And this mornig when i was leaving my house i turned the vdc off since it snowed and as soon as my tires spun it would trip the lights and start jerking and i would let off and i tried to go again and it did it again so i just parked it. Started when i got home and the security light was on but shut off after a few awhile. Could it be a problem with the cd player wiring causeing this? Oh and i couldnt get it to act up when i got and was messin with it
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
