What ECU do I have
Old Jan 19, 2011 | 03:33 AM
  #31
MM_G3520's Avatar
Originally Posted by kyemaul
This thread was def for you. I was waitin on your answer because a while back I read you talking about the ecu change and the production of the new ecu dates. I'm going to up to uprev for them to take a look at and tune the car hopefully the problem goes away.
I believe the early ECUs were AM6000 to AM6004. I have an AM6001. I just called UpRev back in the day, and they cleared it up for me. I called the dealership first, gave them my VIN, and they told me the ECU code, then I called UpRev.
I have an 02/02 build date. I think the switch was sometime in late 03. I think most guys with an 02 build date are... screwed.
Old Jan 19, 2011 | 04:47 PM
  #32
kyemaul's Avatar
i Called uprev this morning and they told me they use to not me able to do the old maximas and g35 a yr ago. They told me they even tune 01 maximas all the time they have the capilbilities to do so. Hope eveything works out when i get down there this weekend!
Old Jan 19, 2011 | 05:39 PM
  #33
NFSP G35's Avatar
? = 2B || !2B
^I just called them and asked if that was the case, and he told me they had looked into doing it, but it just wasn't possible without a huge software projecct that they have no plans to do.
Old Jan 19, 2011 | 05:44 PM
  #34
Jeff92se's Avatar
Red Card Crew
Yup. I actually had an Osris cable and was in contact with them quite a bit before. (trying to gunine pig this **** for you guys)
Old Jan 19, 2011 | 06:01 PM
  #35
kyemaul's Avatar
Where are you located? This guy at a shop that is authorized to do uprev tuning in NY told me we tune 00' 01' 02' with no problem he said he has seen a problem with the A/T 03' G35 but that was like a yr ago. Man I hate getting wrong information!! When I go there this weekend i will have all my answers.
Old Jan 19, 2011 | 06:06 PM
  #36
Jeff92se's Avatar
Red Card Crew
In the NW area but I was talking to UpRev directly.
Old Jan 19, 2011 | 06:16 PM
  #37
NFSP G35's Avatar
? = 2B || !2B
I also called uprev directly.
The number is on their site
Old Jan 19, 2011 | 06:18 PM
  #38
Jeff92se's Avatar
Red Card Crew
Oh yeah? I emailed them.
Old Jan 19, 2011 | 06:32 PM
  #39
kyemaul's Avatar
Just got off the phone with uprev directly and they said that to his knowlegde the production date was Nov of 2002 for the newer model ecu. Mine is sept of 2002 So im screwed !!
Old Jan 19, 2011 | 06:34 PM
  #40
kyemaul's Avatar
If i was to get the newer ecu what would i have to do install and tune?
Old Jan 19, 2011 | 07:48 PM
  #41
NFSP G35's Avatar
? = 2B || !2B
^We're working on that right now.
One thing you'll need is a new gas pedal.
Actually, you only need the sensor at the top, but it's hard to find just the sensor, and the dealer only sells the entire pedal assembly.
Best bet would be a 350Z pedal assembly used. Should bolt right in, has the new sensor, and looks way nicer than the dopy sedan pedal.
Old Jan 19, 2011 | 09:27 PM
  #42
kyemaul's Avatar
Why new gas pedal?
Old Jan 19, 2011 | 09:37 PM
  #43
NFSP G35's Avatar
? = 2B || !2B
^Our cars have an electronic throttle body, so the gas pedal isn't directly linked with a cable like it used to be on older cars.
Instead, there is a sensor on the top of the pedal (Accelerator Pedal Position, or APP, sensor)
On the newer G computers, this is a 5 volt sensor.
On ours, it's 2.5v.
Fortunately though, they plug in the same way, and can be swapped. The problem is Nissan (or most junk yards for that matter) don't sell just the sensor. They sell the entire pedal assembly.
I did find one place you can get the sensor only, but it's $88 before shipping.
For that price, you might as well get a used 350Z pedal assembly because it's a lot nicer than the sedan pedal anyway.
Old Jan 19, 2011 | 09:53 PM
  #44
kyemaul's Avatar
Do you think that plus the blitz throttle controller would help the throttle responses.!
Old Jan 19, 2011 | 09:54 PM
  #45
NFSP G35's Avatar
? = 2B || !2B
