What ECU do I have
Old Jan 18, 2011 | 04:50 PM
kyemaul's Avatar
What ECU do I have
Im having ecu problems. I wanted to know what model ecu i have. I called infiniti they said the production date was sept of 2002 and that the ecu that came with my car is 23710. My question is whats the dates where the ecu was changed. I have Non Doggy Door.
Old Jan 18, 2011 | 05:02 PM
Jeff92se's Avatar
Red Card Crew
Most likely you have the black connectored more modern G35 ecu.
I have not come accross any non-doggies with the early gray connector maxima ecu
Old Jan 18, 2011 | 08:58 PM
NFSP G35's Avatar
? = 2B || !2B
IIRC a lot of the changes from 03.0 to 03.5 happened it 08/02... so you just might have the newer ecu.
Old Jan 18, 2011 | 09:07 PM
MM_G3520's Avatar
Call UpRev with that info and ask them if they offer support. If they do not, you have an early ECU.
Old Jan 18, 2011 | 09:32 PM
kyemaul's Avatar
This thread was def for you. I was waitin on your answer because a while back I read you talking about the ecu change and the production of the new ecu dates. I'm going to up to uprev for them to take a look at and tune the car hopefully the problem goes away.
Old Jan 18, 2011 | 09:33 PM
NFSP G35's Avatar
? = 2B || !2B
^Don't quote me, I'm not 100% sure
Your absolute BEST bet would be to simply get to your ECU and check the connector style.
Old Jan 18, 2011 | 09:39 PM
kyemaul's Avatar
How the heck do I do that. Lol where is the ecu located in the car is it under the driver seat?
Old Jan 18, 2011 | 09:53 PM
NFSP G35's Avatar
? = 2B || !2B
Wait, I found it.
All you need is the last 6 digits of your vin number:
APPLICATION NOTICE PFP:00000
How to Check Vehicle Type ABS0094O
Automatic Transmission
Up to serial 329287
except 327918, 327920,
327976, 327978, 328979,
329004, 329025, 329078
TYPE 1
For serial 327918, 327920,
329004, 329025, 329078 and
from serial 329288
TYPE 2
Old Jan 18, 2011 | 09:58 PM
kyemaul's Avatar
Wait, I found it.
Up to serial 329287
TYPE 1
from serial 329288
TYPE 2
The last 6 is 303808
kyemaul's Avatar
So from my understanding type 1 would be the old ecu?
Old Jan 18, 2011 | 09:59 PM
NFSP G35's Avatar
? = 2B || !2B
Yeah.
Bummer... sorry dude
edit: I'm assuming your car is an Automatic, right?
Old Jan 18, 2011 | 10:02 PM
kyemaul's Avatar
Yea its an a/t so does that mean uprev can't tune my ecu?
Old Jan 18, 2011 | 10:03 PM
kyemaul's Avatar
I don't understand why if I don't have the doggy door this really just upset me a lot !
Old Jan 18, 2011 | 10:13 PM
thescreensavers's Avatar
Mr.202?
Wait, I found it.
Up to serial 329287
TYPE 1
from serial 329288
TYPE 2
Do you think Nisan Fast will show what ECU he has from the VIN?
Old Jan 18, 2011 | 10:23 PM
NFSP G35's Avatar
? = 2B || !2B
^IDK. I forgot to install it!
