03 Sedan Tein H-Techs
Old Jan 26, 2011 | 03:32 PM
03Gdirty's Avatar
If I put the coupe H-Techs on my sedan will i need a camber kit?
I want it to be low like this, but funds are low....
Im on the OEM sport suspension btw
thanks in advance
also pics with this setup would be great
Old Jan 26, 2011 | 11:22 PM
5150DS's Avatar
If you go lower than 1 inch you will need camber kits. Since the coupe springs lower the sedan about .5 inches I am pretty sure you will need camber kits in a bad way with these springs.
Old Jan 26, 2011 | 11:32 PM
mkvl127's Avatar
i have sedan tein H techs on my 05 sedan and i dont need a camber kit and im prob dropped atleast 2 inches..with that extra 1/2 inch u might need a rear..but i doubt it..u want a little bit of negative camber for better handling..id install em and see how close to spec they can get em
Old Jan 27, 2011 | 12:02 AM
NFSP G35's Avatar
? = 2B || !2B
That greatly depends on your definition of "need"
^Yeah. that.
Old Jan 27, 2011 | 12:43 AM
03Gdirty's Avatar
well im on stock 17's so will rubbing be an issue?
I know that it will work without it lol
But i just dono how drastic this is going to throw my car outa wack
I know of a local craigslist seller with 04 350z (track) springs struts and shocks,
and his car has 36000 miles on it and he said they only have 15k
im on stock everything with 147000 miles on her
no problems what so ever by the way
its my dads old car and im 17 so trying to spruce up the grocery getter (no offence)
Old Jan 27, 2011 | 01:50 PM
KissMySVT's Avatar
With 147,000 miles on the car, i don't think the stock shocks would last too much longer w/ the H Techs on it?
Old Jan 27, 2011 | 01:58 PM
NFSP G35's Avatar
? = 2B || !2B
With that many miles, you stock shocks are dead anyway
Old Jan 27, 2011 | 03:42 PM
mkvl127's Avatar
if you need all new struts and springs u might as well get coilovers..good struts r going to run you like 500$ at least...then another 2 and change for springs..for another 3 u can prob get coilovers nd then you'll have more adjustment
Old Jan 27, 2011 | 05:46 PM
Blue Dream's Avatar
I drove ttrank's car solo
Best advice yet^^^^^
OP you can shop around the forum and our vendors to score a good deal on coilovers. Just do your research to make sure you get what you want.
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
reavensf
Sep 17, 2015 11:30 PM
andresito7
Aug 1, 2015 04:53 AM
Popes
Jul 29, 2015 05:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
