Winter Time Cold...
Old Feb 8, 2011 | 08:17 AM
JeromeG35's Avatar
Winter Time Cold...
hi, I have an 04 G35 sedan, and I only have this problem in the winter. My G35 has problems starting when its cold. I have to step on the gas to start my car. I'm not sure if I need a new starter or what. If anyone knows would appreciate the feedback.
Thanks.
Old Feb 8, 2011 | 12:24 PM
The X Factor's Avatar
Have your battery tested to see if it is performing as well as it can. My battery is "passable", but not as good as it can be, so on extra cold days it struggles a little to turn over.
Old Feb 8, 2011 | 12:26 PM
Songle6MT's Avatar
you shouldn't have to step on the gas for your car to start.
Does your battery feel like it's struggling more than usual, if it's weak that would probably be a good place to start. I highly doubt it's your starter unless your battery is strong.
Old Feb 8, 2011 | 01:32 PM
infinitig35's Avatar
I had a similiar problem the temperature first dip below 32 degrees. After a week or so, and driving it everyday, the car starts up in the morning normally without any hesitation.
Old Feb 8, 2011 | 02:16 PM
geew1z's Avatar
For a fuel injected car, it is certainly not normal to have to hit the gas to start it. Also cannot see how that would have anything to do with the starter.
Old Feb 8, 2011 | 06:27 PM
JeromeG35's Avatar
got a new battery last winter.
Old Feb 8, 2011 | 07:13 PM
Songle6MT's Avatar
Still get it tested. Batteries can go bad within a short time sometimes. It is the most likely thing that is the culprit, never hurts to check.
Old Feb 8, 2011 | 07:21 PM
JeromeG35's Avatar
sounds good. thanks for the help
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bjo16
Aug 4, 2015 09:52 AM
multimut
Canada
Jul 26, 2015 08:43 PM
Kal Hamm
Jul 24, 2015 08:55 AM
