G35X AWD / Snow Question
Old Mar 2, 2011 | 01:07 PM
  #31
csvencer's Avatar
Originally Posted by MidnightG35X
If you are hearing a noise directly below the center console, you are hearing the transfer case modulating the power being transferred to the front wheels. If you hear it coming from near the tires, you're hearing the VDC applying the brakes to specific wheels. Our transfer case uses an electromagnetic clutch, so you're hearing that being actuated. You can turn off AWD by pulling the transfer case fuse.
For more info on the AWD vs VDC, see posts by myself and others https://g35driver.com/forums/g35-sed...-you-know.html
And that brings me right back to my original question. When I slip in snow I hear the clutch under the center console sending power to the front axle, now why don't I hear that when I hit the snow button while stopped. It should be doing the same thing as when I slip, sending 50% of the power to the front but you don't hear it. Thoughts?
-Svence
Old Mar 2, 2011 | 01:26 PM
  #32
Jerimiah's Avatar
So I can pull that fuse and dyno my car with no ill effects?
Old Mar 2, 2011 | 02:17 PM
  #33
MidnightG35X's Avatar
-Svence
I certainly think the noise is loudest when the amount of power being sent to the fronts is changing, not just being active. In snow mode, its locked at 50/50. I can hear the transfer case in snow mode if I turn off the heater and radio, but it is pretty faint. You can hear it click back to the full rear at speed. When locked at 50/50, the clutch is already engaged. When you are hearing the noise the loudest, the clutch is not fully engaged. The speed at which the clutch can change power distribution is very quick due to being electromagnetic, not straight mechanical.
Old Mar 2, 2011 | 04:51 PM
  #34
csvencer's Avatar
Sounds about right, thanks for the logical explanation.
-Svence
Old Mar 2, 2011 | 05:37 PM
  #35
OKStateG35's Avatar
I guess you could try it, but I wouldn't punch the gas at first unless you want to risk putting your car through the wall.
I have not dynoed my car so don't blame me if something goes wrong.
Old Mar 3, 2011 | 12:22 AM
  #36
drkay's Avatar
^ I remember reading that the front wheels will still rotate with the fuse pulled. . .
Old Nov 16, 2013 | 03:28 PM
  #37
jojo89's Avatar
the transfer case switch sounds cool!! can ya tell me how ya did it? id like to try it!!
Old Nov 20, 2013 | 05:33 PM
  #38
apintojr's Avatar
Originally Posted by Dreamin4Awhile
Im extremely confused. I thought AWD meant that when I had the snow button o I was in AWD. Now what your saying is that its only RWD above 12 mph? Somebody please explain a little better.
Thank You
in good conditions, the care is pretty much RWD. at the start is usually 25%front 75%rear, and if the road conditions are good and dry the car basically transfers 100%power to the rears until it detects anything and adjusts.
Snow button lowers throttle response, and locks it at 50/50. this is basically only needed for full starts from a dead stop or parking spot. pretty much for no wheel spin action. so if your at a dead stop, and have the snow button on you can mash the pedal all you want, there will be a throttled down response. the snow button features disengages after 12mph i think. something around that area anyway.
Old Nov 21, 2013 | 08:18 AM
  #39
Bassman's Avatar
To add to the clearification, if the rearwheels start to slip above 12 mph the computer will transfer the appropriate amount of power to the front seamlessly. You woun't even notice it except when you see you're moving and everyone else is stuck.
Old Nov 21, 2013 | 10:38 AM
  #40
Mustang5L5's Avatar
To sum it up in a short sweet sentence. The car is mostly RWD, with just enough AWD control to make it pretty confident in low traction situations.
Old Nov 21, 2013 | 11:49 AM
  #41
Wannabe6MT's Avatar
-MN G Crew-
Good winter tires and you won't hear that noise ever. It isn't AWD engaging, it is just your VDC working out the traction situation.
Alex Koss
Oct 29, 2021 12:53 PM
Cajuncowboy
Jun 21, 2021 09:47 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
