looks like i'm not comming back to this shop again,,,
brake fluid level is way to high,,,,,this i can pump out
powersteer is low....... its ok, can add, just wondering which fluid?
atf is way high,,,i guess i will try to pump it out
Good lord... Did they even look to see what they were doing. That is embarassing for them. a5 window tinting hillsboro oregonOriginally Posted by cmex
ATF level, when/how did you check it?
that thing fluctuates like the economy under Bernake/Obama...
^as opposed to being completely rock bottom under bernanke/bush. Just sayin.
Seriously though, you checked it with the engine running, right?
Quote:
the one i'm never comming back to Originally Posted by express705
and which shop is this lol
)))about AFT level
they did not replace the nut on top so i can pull the stick out same just like to check engine oil level ...... my car sat to 2 days ,,, on level ground,,,, and the level is 1 1/2in more on the stick
it was the same level after 30 driving too 2 days agoon top of this all, then i got the car coolant was way way way low too
heater did not work so i had to drive back,,, i should have waited and do it all my self
