New owner - Questions about things I need to fix
Old Mar 20, 2011 | 09:13 AM
sloppymax's Avatar
Out of town right now but should be able to check tonight.
Old Mar 20, 2011 | 11:11 AM
acr's Avatar
acr
Those finishers occasionally come up for sale in the marketplace. The dealer tends to be expensive.
Old Mar 20, 2011 | 12:34 PM
ridinG's Avatar
sloppymax, no rush. Just reminding you in case you forgot.
acr, I've seen some old threads with people selling "finishers", but the thing is I think those are the finisher+circuit board due to the problems with the radio. I was under the impression this is just a plastic panel that you can swap on.
Update 1: Actually, sloppymax I think you've pointed me in the right direction. I had came upon this thread: Yellowing tirm on 06 sedan, but had initially ignored it since it was an '06 and I have an '05. But since you say that 05/06 should be the same part, I think I have the info I need:
Based on post #35,:
Originally Posted by Mustang5L5
"CUSTOMER STATES CENTER CONSOLE TRIM ABOVE ASHTRAY IS TURNING YELLOW, PLEASE CHECK,...CUSTOMER DOES NOT SMOKE
RADIO FINISHER'S ARE DISCOLORED
REPLACED RADIO FINISHER"
PARTS
FINISHER-RADIO 28042-AC703
LID ASSY-CLUSTER 68260-AC710
These were the p/n's I had to go off of, but since I didn't know if 05 and 06 were the same, I thought there would be some variation in them.
28042-AC703 is $18.55 (on dealerdirectparts.com)
68260-AC710 is $154, but I don't think I need it since I think this is the ashtray/cigarette lighter lid, which is not discolored on my car.
Since the first one is only 20 bucks, I'll just order it & if it works, good. Otherwise, the search continues.
Update 2
I think I found the info I needed about the rear window creaking/popping when windows-all-the-way up here: DIY: 03-05 Sedan Rear Door Rattle/Creak TSB Repair and Panel Removal. p/n of the bolts are 01125-03241 and you need 2 per side.
Old Mar 21, 2011 | 07:57 PM
sloppymax's Avatar
The radio finisher matches what you have listed but for the lid assy-cluster, mine says 68260-AC700 so maybe they updated the part since I had mine replaced. My advisor backed up what some stated that it was the adhesive coming through over time when it was hot and discoloring the trim.
Old Mar 22, 2011 | 10:49 AM
ridinG's Avatar
Cool, glad the p/n's match - but about the p/n diff of the lid-assy: how long ago did you get yours replaced? The post I quoted was from Feb of 2010 so assuming his replacement was maybe early 2010, late 2009.
The finisher piece should be here by the weekend, I'll update on how it goes.
Old Mar 22, 2011 | 10:53 AM
Mustang5L5's Avatar
i hafd my face replaced about a year ago under warranty.
The new trim is already starting to turn yellow
Old Mar 22, 2011 | 08:03 PM
sloppymax's Avatar
Mine was done June 2009. Since he stated it was heat related, I try to put up the windshield deflector up anytime its in the sun and my windows are tinted but time will tell. If it does it again, I know I can remove it and use the steel wool method. If it looks bad then from what you showed, the replacement is pretty inexpensive.
Old Mar 25, 2011 | 08:33 AM
ridinG's Avatar
Thanks for updating Mustang5L5...but wow, a lifetime of about a year? There definitely must be some trigger. When manufacturers design a car, I would have thought that they did some testing at extreme temperatures for long periods of time.
I don't wanna go as far as to say a defective radio causes the yellowing, but who knows. Have either of you experienced problems with your radios or having to need a jump start/replace battery? I'm gonna see if I can take the finisher off, play the radio for a while & see if the area under where the finisher was yellowed is unusually hotter than the rest of the unit.
Old Mar 25, 2011 | 08:34 AM
ridinG's Avatar
And no signs of yellowing again yet?
Old Mar 25, 2011 | 08:36 AM
sloppymax's Avatar
None to report so far.
Old Mar 25, 2011 | 09:26 AM
Sacch's Avatar
I had my car for about 6 years NO yellowing.
Old Mar 26, 2011 | 10:04 PM
ridinG's Avatar
...not so fast....
The part came in today....but it is not the correct part. The part which I was assuming to be the aluminum finish ("FINISHER-RADIO 28042-AC703") which was 20 bucks is actually the small dark plastic piece that the radio display shines through:
"LID ASSY-CLUSTER 68260-AC710" must be the part we need...and that's 150 bucks.
The box it came in was pretty large, but once I opened it, this small flimsy piece fell out
Old Mar 26, 2011 | 11:14 PM
The Fixer's Avatar
Damn, that's beat! I guess I'll be trying the 0000 steel wool trick and some aluminum polish on mine, since they're no way I'm coughing up $150 for new trim. That $150 is most of the way towards a plenum spacer.
Old Mar 26, 2011 | 11:54 PM
Mustang5L5's Avatar
No, no radio or battery issues here. The yellowing is only just starting on the very edge. Not as bad as when I replaced it...but I can def tell it's coming back. The finisher is a little warm after a drive. I bet the discoloration is simply heat related from the center console.
Guess I'll just live with it because I'm not spending $150 on another one. My shift **** is showing it's age too. I guess the oils on my skim are doing a number on it because the finish is deteriorating badly.
DimQ
Aug 14, 2015 02:04 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
newg37
Jul 26, 2015 09:32 AM
