Repairing the crap out of my G.
so i need to replace the drive belts
looking to order these --> (http://cgi.ebay.ca/2006-INFINITI-G35-SEDAN-OEM-DRIVE-BELTS-/180630183232?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AG35&hash=item2a0e65dd40)
need to replace front left and rear right wheel bearings
looking to order these --> (http://www.autopartswarehouse.com/se...ck+Replacement)
and also i need to replace both front compression rods
still looking for these, any advise? can the links above be trusted?
a compression rod being bad wouldnt really be noticeable by your or driving, its like one of those parts that can be bad and you wont even know it youll be driving just fine
you sure it isnt your control arm bushings??
it is indeed the bushing, but it can not be replaced on its own the entire arm is required
^The bushing themselves can be replaced, but you'll have to take them to to a shop with a press to have the old ones pressed out and the new ones pressed in. If you think the ball joint on the compression rod is going bad too, then I suggest getting a whole new rod.
Compression rod bushings are known to go out as well, control arm bushings don't go bad as often.
He is correct
Please do not recommend this to anyone. I have done this, bought a new bushing for 25$ + tax and delivery, got it pressed in for 70$, and the noise got reduced slightly. after 2 months its back full force so i wasted over 100 dollars for nothing.
That sucks you have already replaced the bushings and it didn't take care of your problem. Some people have had luck with the revised compression rod bushings.
What kind of noises are you hearing?
You obviously have never driven on a bad compression rod. It WILL effect the way car drives, both handling and steering. Trust me, I drove on a bad one for a little over a year.
a compression rod doesnt do anything its the bushings on it, which can be bought thats why i asked if hes sure! because its pretty hard to break a piece of steel,
so i know what i was talking about, i drove on a bad BUSHING just like you not a compression rod
what bushing did you buy for a 25 bucks when they're around 70 cheapest and it costs 10 bucks to get it pressed in!
bushing is the only thing that can go, so its your bad luck got a ****ty bushing
here buy some here, great stuff which is reinforced unlike oem stuff
http://www.jscspeed.com/catalog/Niss...initi_G35.html
also check out g35parts.com
way better then the oem replacment ones which suck major dick!
these type of bushings blow ***** thats why they're ****ty
http://www.mynismo.com/products/?id=5348
which is what oem ones look like
it sounds like a metal to metal clunk going over bumps at at low speeds. i went to infiniti to get it checked out and they confirmed it is the compression rod
