my car turn off idk why. help -____-
to be honest...if your car was working fine before the pump, you shouldnt suspect that its a busted fuel system...try fixing the cheapest part first then, with process of elimination, work yourself to worst case scenario...
in my opinion, it sounds like the problem i had with my G along with other peeps on this forum when they disconnected the battery, had an ecu reset, or done anything to their car..
my solution was a two step process:
1. reset the ecu, idle position sensor, and throttle body
http://www.line-it-up.org/threads/22...earn-procedure
if problem persists, its most likely your throttle body having carbon build up...mine was caked. i cleaned mine and it she didnt hesitate once after
check my thread:
https://g35driver.com/forums/g35-sed...-solution.html
hope this helps ya brada...good luck
check my thread:
Hasanbaloch
Feb 29, 2024 08:45 PM
blame the world first hahahah
