Valve cover salvageable????
Old May 1, 2011 | 03:06 AM
seebas's Avatar
Thumbs up Valve cover salvageable????
I Picked up some valve covers from my buddys shop...however, after some inspection, i noticed that the nipples broke off the covers...the arrows in the picture attached shows what im talking about...
these nipples are join together by a tube located in front of the engine bay...
can i still use these? can the nipples be replaced? can they just be blocked off?
If they can just be sealed up, what methods do you guys suggest?
Old May 1, 2011 | 05:17 PM
Max626's Avatar
I believe they are plastic nipples in a rubber grommet with that being said you can find a replacement at any parts store
Old May 1, 2011 | 06:02 PM
seebas's Avatar
They won't budge tho...on either side haha...I'll try to carefully drill them out tomorrow.
Old May 1, 2011 | 06:27 PM
Max626's Avatar
i think other members when installing a catch can system have tapped some AN fittings give it a quick search
Old May 1, 2011 | 06:38 PM
seebas's Avatar
What do you mean? AN fittings?
Old May 2, 2011 | 12:40 AM
seebas's Avatar
bumpity bump bump
Old May 2, 2011 | 12:40 PM
seebas's Avatar
For those of you who are curious...these parts are not replaceable. I called my infiniti dealerships around and they stated that those nipples cannot be replaced...
So for those looking at taking off that PCV hose for whatever reason, BE CAREFUL THEY ARE EXTREMELY BRITTLE.
Old May 2, 2011 | 01:26 PM
Heist.'s Avatar
just tap them and put an an fitting
Old May 2, 2011 | 01:42 PM
seebas's Avatar
How so? I mean what kind of material can you use to seal the tap?
I personally would use aluminum tubing from like a hardware store to make new nipples but what material could you use to reseal the tap without worrying about any leaks? Fiberglass? Epoxy? ...
Almost worth buying a pair of VC to make sure that no leaks will occur during high pressure...any input on any of this?
Old May 7, 2011 | 03:59 AM
RRYDE's Avatar
Do you have pictures of the actual valve covers that are damaged ?
It would help better to actually see the damage to be able to give suggestions on a fix.
Old May 7, 2011 | 05:38 PM
OCG35's Avatar
have you renewed your sedan clearance membership?... If it has expired you need to get a sedan or get out.
aw never-mind, we gave you a lifetime membership years ago... you can stay
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
doakley92
Sep 25, 2015 12:58 PM
