Anyone know MIN rotor thickness for front rotors?
Old May 22, 2011 | 11:10 PM
Mustang5L5's Avatar
82k miles, need to do front brakes again for 2nd time.
Still have front rotors from the first brake job. They look great, so I want to cut them and reuse them. What's the min thickness though?
They barely look worm, so I'm probably good.
Edit: for an 06, front, with 12.6" rotors
Old May 22, 2011 | 11:37 PM
S 854's Avatar
IIRC, the 12.6" fronts are at nom 28.1mm and min is 26mm.
12.1" Rears are at nom 16mm and min is 14mm.
Old May 22, 2011 | 11:50 PM
Mustang5L5's Avatar
Thanks.
Front are 27.9, so I guess I'm good to go to get them cut and use them.
Rears are toast. I knew they were too thin, so I just let them go and said I'd change them when the pad backing plates started to scrape...which was 2 days ago. Got new rotors and pads for the rear going on next weekend.
Old May 23, 2011 | 10:20 AM
Swivel's Avatar
Moderator
How much do they take off when turning rotors? Guess it depends if they are grooved or whatever...but assuming they are in otherwise good shape?
Old May 23, 2011 | 10:39 AM
Bassman's Avatar
I'm having the same problem as the OP on the wife's '05 Maxima. Same brakes as an '05 G35x. So, I'd like to know how much is typically taken off when a disc is "turned" too.
Old May 23, 2011 | 10:48 AM
Swivel's Avatar
Moderator
Some quick research tells me about 0.020" or 0.5 mm but maybe Blanchard grinding is better than turning.
Old May 23, 2011 | 12:24 PM
Mustang5L5's Avatar
I'll get a measurement when i get them done this week, but I think it's something like 0.010-0.020" or so.
Of course, it depends how out of true they are. These were not bad at all. When my car needed brakes, i ordered new rotors just for the hell of it. With the old rotors off, they looked perfectly fine, so i didn't want to throw them out. No grooves, or abnormal wear. If i really wanted to, i could prob toss them back on as-is...but i'd rather do a light resurface first.
Old May 24, 2011 | 07:33 PM
ttrank's Avatar
Grocery getter
Mine are 38mm
Many rotors will have the min stamped onto them.
I agree with the others above. It all depends on how much material they take off. You can specify that they only take them down to a certain amount if it works for you. I'm talking auto parts stores who turn them, not shops.
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
RedBaronK
Jul 27, 2015 03:19 PM
