Front End Creeking?
Old Feb 19, 2005 | 11:27 PM
  #31
subrobo's Avatar
Hope this helps,
https://g35driver.com/forums/g35-sedan-v35-2003-06/44847-new-noise-my-g35sedan.html
Old Feb 19, 2005 | 11:57 PM
  #32
ABQ_G35's Avatar
Originally Posted by 6MTsdn03
what symptoms did you have with the rear suspension? Why they replaced the rear stabilizer connecting rod? second time? I have some concern that the back of my car does not want to stay straight.
Sorry it took so long to reply, I forgot I had posted this. The bushings were "loose" on the connecting rods, I didn't feel any control issues, I just was getting a noise from the rear that sounded almost like something was rolling around in the trunk, and maybe a slight "popping" sound, so far it seems to have worked the second time with the revised part number!
Old Feb 26, 2005 | 03:24 AM
  #33
6MTsdn03's Avatar
Anyone with an update? my front end noise is really pronounced and annoying, Infiniti keeps saying it is normal
Old Feb 26, 2005 | 01:41 PM
  #34
g35girl's Avatar
Unimaginative, Indecisive User
i've taken my sedan in twice for front creeking. first time they couldn't hear it. second time, i took the tech for a ride and he heard it. this is from my 1/26/05 invoice:
"C/S hearing creaking coming from both frt pass and drivers wheel area going over small bumps. frt cowel making noise at base of windshield. installed foam padding on cowl per bulletin ITB02-060." labor 0.5 hrs.
i have a 2003, so i'm not sure if this will apply to 2004 models. good luck everyone.
Old Feb 27, 2005 | 03:09 PM
  #35
Noremac's Avatar
g35girl- Did the cowl fix solve your creaking problem? If so, would you have guessed that the sound was coming from the windshield area before getting that diagnosis? (Mine definitely sounds like a suspension and/or underbody sound.)
Old Feb 27, 2005 | 06:54 PM
  #36
6MTsdn03's Avatar
Mine seems to be suspension related; it also seems to be widespread issue.
Old Feb 27, 2005 | 10:52 PM
  #37
ABQ_G35's Avatar
I think the creaking you are referring to, may be fixed by a TSB Does the creaking sound like the AFLAC duck at all? It sayss that TSB is for the '03, but they also did it to my '04 a while back, I also read a post somewhere that the material they use for the bushings is prone to squeaking sometimes.
Old Feb 28, 2005 | 04:47 AM
  #38
6MTsdn03's Avatar
The dealer categorically said that the noise is not related to this TSB; I had a print out with me, he was familiar with it they had applied to some cars early on.
Old Feb 28, 2005 | 05:49 AM
  #39
Birdhouse's Avatar
It's Lonely At The Bottom
Question
I have a 2005 G35 Sedan. Everytime I turn on the car and go at least or near 2,000RPM I hear this buzzing-spring lock sound. This happens all the time when I start and go.
Is this the ABS system or something else?
Old Feb 28, 2005 | 09:43 PM
  #40
g35girl's Avatar
noremac... unfortunately, no. i posted that TSB in the hopes that it might help another forum member. the creaking is still there and sounds similar to yours. when the car's body moves in an up-down motion (like when driving through a shallow dip or backing out of an elevated driveway), i can hear the creak.
birdhouse... that sounds like it is your ABS check. if so, be sure not to hit your brakes when it's doing that or the sensation you feel in your foot will kind of freak you out (as if you broke something).
Old Feb 28, 2005 | 09:57 PM
  #41
6MTsdn03's Avatar
I don't think that there is an identified fix for the problem. I have registered a complaint with Infiniti consumer affairs; the more owners demand a solution the better our chances finally have it fixed.
Old Mar 15, 2005 | 08:19 PM
  #42
6MTsdn03's Avatar
Does anybody have an update on this?
Old Mar 15, 2005 | 09:41 PM
  #43
sickpig's Avatar
Just got mine fixed today. There IS a TSB on it. They performed a "body panel adjustment". Under warranty. Couldn't duplicate the creaking and popping from the base of the windshield though. At least I can go over a speed bump without souding like a squeaky old truck.
Mark
Old Mar 15, 2005 | 09:59 PM
  #44
3Aims's Avatar
Mark
Did your service provider explain the body panel adjustment?
Old Mar 15, 2005 | 10:35 PM
  #45
6MTsdn03's Avatar
Do you know the TSB #?
