Air bag flashing Light - G35 Sedan 2005
Old Jul 2, 2011 | 03:00 AM
Ustraveler's Avatar
I have reset the flashing light numerous amount of times but still keeps on flashing.
Any suggestions?
Old Jul 2, 2011 | 05:49 AM
butkiss1's Avatar
Flashing light indicates system problem , Go to mechanic that has Nissan code reader and find out which bag is throwing the code,
Do you have Racing Seats?
Old Jul 2, 2011 | 07:36 AM
XMFAN775's Avatar
Any suggestions?
I have had the same issue since January. I finally took it to the dealer this week and they are quoting me $1,800 to fix the RH passenger side airbag. I hope your issue isn't as pricey as mine....
*** Name to be changed to XMFAN775 shortly to avoid confusion with the "real" G35 Mass......... ***
Old Jul 2, 2011 | 08:44 AM
GeeWillikers's Avatar
Walking The Fine Line...
^LOL...
Would take it to get codes read too - bag problems usually aren't cheap.
Old Jul 2, 2011 | 02:12 PM
Ustraveler's Avatar
I was driving and it just keeps on flashing. I was reading about the recall on infiniti's but don't know if my car's eligible...
Old Jul 2, 2011 | 07:33 PM
conesweeper's Avatar
My car also has the air bag light flashing.. 2005 as well
Old Jul 2, 2011 | 07:49 PM
butkiss1's Avatar
Buy the Airbag used(Never deployed) from KC Nissan for a fraction of dealer cost
Old Jul 2, 2011 | 08:02 PM
boostedforlife's Avatar
I already had the airbag recall done, and now the light came on too as well after the fact,
do you know if uprev/ cypher can tell? or do I have to take it in to the dealer?
Old Jul 2, 2011 | 08:53 PM
ronniepetras's Avatar
Had the same problem took it to the dealer & they fixed it for free mine is an 03 there was a recall on the 03 from what I have read!
Old Jul 3, 2011 | 12:02 AM
BuzzLightYear's Avatar
Its crazy because my 05x recently had the same issue also. Took it to the dealer, ended up being that my driver side, side airbag needed to be replaced. Luckily I was covered under warranty! Sounds like a common issue on the 05's.
Old Jul 3, 2011 | 12:09 AM
04G35NYC's Avatar
umm, it's a recall issue TSB!!!! This should be a free of charge replacement.
Old May 16, 2013 | 04:53 PM
mikep415's Avatar
This issue just came up today on my 05 g35 sedan. I called the dealer and they said my vin wasn't eligeble for recall... =(
Old May 16, 2013 | 08:44 PM
neo_anderson302's Avatar
Undo the recall.
Old May 17, 2013 | 12:40 AM
Blue Dream's Avatar
I drove ttrank's car solo
Have you tried to reset the light? If not turn you ignition off and on w/o starting the car 4 times. If it's not a serious issue with the airbag this should turn off the light.
Old May 24, 2013 | 03:56 AM
05CoupeMT's Avatar
G35 Coupe 6MT
not on 05/06 models.. it works for a day or so and then start blinking again.
