Wheel Bearings and Rear Arms
Old Jul 11, 2011 | 02:56 PM
takeitez's Avatar
Sorry if this is noob question but,
Wheel bearings....same as bushings? I know the clunking sound is the bearing, and I know that they can be taken off the arm without getting pressed even if they're really stuck on there, but not sure which part to order from which vendor.
Also, my mechanic said that i need the two lower arms on my rear left, not sure what they're called either? Trailing arm and what else?
thanks for the help!
Old Jul 11, 2011 | 03:53 PM
Mustang5L5's Avatar
Well, which bearing do you need? What do you drive?
There are 3 different bearings and hubs depending on front/rear and RWD/AWD.
Old Jul 11, 2011 | 06:48 PM
takeitez's Avatar
04 sedan x , so AWD. should be only front left bearing thats making noise...but because the humming is very loud, i'd assume doing both bearings is best idea?
Old Jul 11, 2011 | 08:33 PM
Mustang5L5's Avatar
Normally I'd say yes..until you see the price of the bearings and hubs. You should change the hub as well, but not required. Prob cost oyu in the ballpark of $250-400 in parts for each side depending on where you buy from. So i'd just fix what's broken and nothing more.
I'm about to do this on my car...have a read.
https://g35driver.com/forums/g35-sed...-bearings.html
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
