Will AC work without the radio?
Old Jul 31, 2011 | 05:43 PM
whiggy's Avatar
I need to take out the radio and send it off for repair (just the radio without the faceplate/controls).
Does anyone know if the AC will work with the radio being out? (2003 sedan)
Thanks.
Old Jul 31, 2011 | 05:54 PM
MikeERideWNC's Avatar
You should rethink the, "send it in for repair..."
It took me five hours to install a new radio. Yesterday!
The cost was under 400.00.
Now I have Hands Free phone, Bluetooth for Slacker and Pandora.
Works with my steering controls and XM.
Here is my write up from another forum:
So I bought a new radio to replace my dieing radio.
I thought it was going to be much more expensive, but radio prices for decent aftermarket units are very reasonable.
I bought the JVC KW-XR810 for 210.00 shipped from Amazon.
I was going to cheap out and get the 610 for 50.00 less but it did not have the features I wanted.
So with the install I needed and new dash mount, XM convertor ( no Cassette deck), Steering wheel convertor and Nissan harness.
This is what it looked like on the table.
The old and new, side by side:
All the wires:
Microphone install:
In the dash:
Now I have Bluetooth to stream Slacker Radio or Pandora.
Plus hands free calling.
I have a USB port for Ipod or to charge my phone.
I have an Aux port for an MP3 player or if glynn wants to listen to his cassettes.
Steering wheel controls work.
The XM is fed through the radio antenna cable.
This was completed for less than 400.00.
With five hours of labor. Not too bad. Jenn's XC90 was much worse.
I may buy the XM receiver someday.
Old Jul 31, 2011 | 05:58 PM
whiggy's Avatar
Thanks, that looks like a great option... however, I am planning on selling the car soon and all I want is my 6 CDs that are stuck in there and OEM CD/radio working.
Old Jul 31, 2011 | 06:02 PM
Quimby's Avatar
have you tried punching the side of the center console near/under the radio? it works wonders.. got all the CD's out of my radio with "CD ERROR FO" or whatever the reading is. It will sometimes even fix the problem temporarily.
ps; I don't mean punching it hard. I think it all has to do with where you hit it..
Old Jul 31, 2011 | 06:06 PM
That is what I was thinking... Smack the right side of the console by the lighter outlet.
If that does not work,
Pull the radio, open it up and place three peices of package tape on the bacl of the ribbon cables on the reverse side of the leads.
Insert the ribbon cables back into the their mate and put the radio back together.
The radio should work fine again.
Old Jul 31, 2011 | 08:15 PM
whiggy's Avatar
Thanks guys! I honestly appreciate you trying to help and I really don't mean to be rude but... I've had problems with the radio for a few months and I have already smacked the sh*t out of the center console a few times and tried all the advices from this and other boards but none of it helped. Now all I want to do is send the radio to this repair shop that will take the stuck CDs out and repair the problem with radio cutting out and AC controls being stuck on auto. This is a known issue with this year and the consensus is that the best thing is to go aftermarket. But.... all I want to do is sell the car (family expanded; need SUV).
So...will the AC work without the radio being in the car or not?
Thanks.
Old Jul 31, 2011 | 08:22 PM
I am thinking...
Wait for it.
Wait for it...
Yes.
You can always pull the radio and try?
It is only fifteen minutes of down time to pull it.
I say yes because it is a separate wire harness for the climate controls.
Old Jul 31, 2011 | 09:00 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I've got a how-to on removing CDs from the radio. If you're only slightly more careful than I am in the video, you'll get them out without any damage to the radio.
As for fixing the rest of the radio... It's not going to get you any more out of the car to fix it, while going aftermarket just might. Bluetooth and iPod compatibility is a good enough selling point.
Old Jul 31, 2011 | 11:14 PM
NFSP G35's Avatar
? = 2B || !2B
I can't believe none of you guys answered his simple question
The A/C won't really work with the radio uninstalled. The OEM unit is all one circuit board with both radio controls and AC controls on the same board.
The AC will kinda work, but will probably default to 75, which really isn't comfortable.
Old Jul 31, 2011 | 11:39 PM
naughty240's Avatar
^plus full blast fan
Old Aug 1, 2011 | 07:38 AM
whiggy's Avatar
Thanks!! That's what I was looking for :-)
I live in FL so full blast is pretty much every time I drive :-)
Also, I could live with 75F for a while.
I'll pull the radio out, then see if AC works at all. If it does, great; if it doesn't I'll try Wrathernaut's instructions to remove CDs and then I'll put the radio back...at least until September.
Old Aug 1, 2011 | 07:46 AM
Mustang5L5's Avatar
In reading the FSM, it will default to last set temp. So if he sets it to 60 before removing, he might have 60 degree air.
EDIT: Copied from '06 FSM
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/atc.pdf
Page 34
Fail-safe Function NJS0005K
If a communication error exists between display and A/C auto amp. and A/C and audio controller for 30 seconds
or longer, air conditioner is controlled under the following conditions:
Compressor : ON
Air outlet : AUTO
Air inlet : FRE (Fresh)
Blower fan speed : AUTO
Set temperature : Setting before communication error occurs
Display : OFF
Old Aug 1, 2011 | 07:53 AM
whiggy's Avatar
Wow, that's even better! :-)
Thanks!!!
Old Aug 6, 2011 | 11:39 AM
whiggy's Avatar
I just took the radio out and AC works at its last setting (70F auto fan).
Thanks to everyone that helped. :-)
arora_g35
Apr 16, 2026 02:52 PM
mike730
Jan 12, 2018 04:25 PM
WillisFL
Dec 29, 2016 08:56 AM
kd03g99
Jul 30, 2015 11:24 AM
realtalk21
Jul 20, 2015 09:07 AM
