Wood In Trunk Under Carpet?
Old Aug 11, 2011 | 03:03 PM
ajkVQ's Avatar
My car's carpet in the trunk is sunk and I was curious if there is supposed to be a wood platform or something to keep it flat and stable. If I put stuff in my trunk the carpet basically just falls onto the spare. I tried searching for it, but can't seem to find it. I bought the car used, so maybe the previous owner took it out for some reason and never put it back?
Thanks!
2006 G35: Foam
2006 G35x: Wood then foam
2006 G35: Foam
2006 G35 with temp spare: Foam
2006 6MT with temp spare: Foam
2004 6Mt: Foam
2005 G35x with full spare: Wood
Old Aug 11, 2011 | 03:05 PM
LordFappington's Avatar
Yes, it probably rotted away or something. Take it out and see.
Old Aug 11, 2011 | 03:33 PM
ajkVQ's Avatar
Just called a local Infiniti dealership...trunk floorboard for $136. For a piece of wood.
Old Aug 11, 2011 | 04:01 PM
S 854's Avatar
Is it really a piece of wood? Underneath my carpet is a foam piece covering the spare.
Old Aug 11, 2011 | 04:02 PM
Get a jigsaw and go buy some plywood and make it yourself or go to an audio shop.
Old Aug 11, 2011 | 04:03 PM
ajkVQ's Avatar
Foam, eh? I've never heard of that...in any car. I wonder if that's factory..
Old Aug 11, 2011 | 04:05 PM
davidxu's Avatar
under mine, theres a piece of wood covering the spare... then foam around the spare
Old Aug 11, 2011 | 04:07 PM
S 854's Avatar
^ Pretty sure it's stock, man. For 05/06's at least. No wood piece I found anywhere:
Old Aug 11, 2011 | 04:12 PM
Mustang5L5's Avatar
Depends on if you have the full size spare or the temporary spare.
For full size spare, you have 3 peices of foam that build the trunk up slightly to sit over the wheel.
For temp spare, it sits lower, and there is a peice of stiff particle board that goes over the tire but under the carpet
Old Aug 11, 2011 | 04:14 PM
S 854's Avatar
^ Ah good to know Mustang, thanks.
Unfortunately 05/06's that came with the sport package could not have a full size spare.....not that I'm packing a spare anymore with the amps down there
Old Aug 11, 2011 | 04:19 PM
ajkVQ's Avatar
Interesting. Well, I guess I'm off to Home Depot to make it for myself.
DivZero's Avatar
I have a temp spare in my 06 and there is only hard foam. Perhaps there is an 03/04 and an 05/06 version.
Old Aug 11, 2011 | 06:19 PM
B T's Avatar
B T
06 6MT with temp spare and hard foam here
Old Aug 11, 2011 | 06:34 PM
PAIXAO's Avatar
04 6MT and I have foam under my carpet.
Old Aug 11, 2011 | 06:52 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
HOLY DYNAMAT!!!, sure way to add 3000 lbs to the car, just exaggerating a bit.
