Alignment Specs
Old Aug 27, 2011 | 09:51 AM
naijai's Avatar
Alignment Specs
I had my alignment done 2 weeks after lowering my car also installed SPC rear alignement bolts. These are the results from the Nissan dealer who said it was back to factory or as close to factory but the tire wear on my rear tires may say otherwise. Can someone confirm if anything else needs to be done to the rear.
Rear Axle Before After
Camber Left -1.05 -0.78
Right -1.18 -0.83
Toe Total 0.07 0.25
Left 0.61 0.12
Right -0.54 0.13
Geometrical Driving 0*34' 0*00'
axis
Front Axle
Camber Left -1.63 -1.63
Right -1.67 -1.74
Caster Left 7.98 8.12
Right 8.64 8.42
SAI Left 5.25 4.91
Right 5.24 5.7
setback 0*04' 0*.01'
Toe Total -0.43 0.10
Left -0.35 0.06
Right -0.08 0.05
Old Aug 27, 2011 | 10:35 AM
DivZero's Avatar
I wish I could get -1.6 camber in the front!
Your rear camber is good. No worries there. Might want to check about the toe... that's what usually eats tires anyway. My advice would be look in the factory service manual to confirm it's within specification. I think you have 1/8" toe in for the rear... which is somewhat significant.
What tire wear are you getting?
Old Aug 27, 2011 | 12:08 PM
pulsar1's Avatar
Everything is with in spec other than the front camber which isn't all that bad.imo What are you lower on, I've never seen such little camber gain in the rear from a lowering spring.
Total rear toe is spec'd at .01*-.43* fwiw
Old Aug 27, 2011 | 01:16 PM
naijai's Avatar
Tokico D-Spec with Eibach Pro kit
I will eventually get the front arm to get camber back to spec
This is what my rear tires look like
Old Aug 27, 2011 | 04:40 PM
pulsar1's Avatar
You lowered your car 2 weeks ago, and the rears looked wore that fast? Or they were already like that. I rolled with no alignment for a month and my tires didn't wear at all. My current alignment spec are waaaay out other than toe, tires still good.
Old Aug 27, 2011 | 06:56 PM
naijai's Avatar
I lowered it 2 months ago. i'm more concerned about the wear pattern on the tires, it don't believe they should be that badly worn on the inside of the tire but according to the service manual the rear is in spec
Old Aug 27, 2011 | 10:51 PM
srv2nv's Avatar
G35 Sport
Did you have any feathering on the tread while it was wearing that fast? Camber, especially with the little that you had, shouldn't wear a tire that fast. Toe would be the culprit, but I can't really tell if you have/had any feathering which would imply your toe being out.
EDIT:
After looking at the original numbers again, the left side toe is further out than the right, which shows on the tires. I'd suspect that was your issue, especially if you had any wobble in the steering wheel while travelling on the highway.
Old Aug 28, 2011 | 08:14 AM
naijai's Avatar
The rear left toe is off by a degree so i guess ill just replace my tires and get my new wheels and tires sooner than expected with the front camber arms and full alignment (again). Thanks for the help guys
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
