Need help on what parts to get 03 Sedan when trying to fix my car
Old Aug 27, 2011 | 10:42 PM
pjgangsta's Avatar
G35X Revup
I'm going to try to fix my car on my own, replace my shocks, and replace my muffler cause the flange is rusted and is disconnected to the midpipe. I'm having some confusion and need some help guys.
I ordered some HP Tokico Blues front and rear shocks/struts
Do I need mounts, boots, rubber bushings?
I'm unsure if I need to buy springs? I just want to go with whatever is OEM or matches to it. I'm a college student with low funds.
Also when doing the direct bolt on for the exhaust, was wondering what
parts I need to get, such as gaskets, ring gaskets...
Having some real confusion....
It seems cool to just direct bolt on and reuse my gaskets but the service manual says always replace them, but dont show any part #"s.
Old Aug 28, 2011 | 12:22 PM
BAUSauto's Avatar
Gaskets are generic.. Kinda like buying a washer.. You can go into Infiniti/Nissan and purchase an OEM gasket and at the same time you can go to your local auto parts store and buy a gasket (make sure the size is right).
I don't remember you needing anything other then the shocks to replace tokicos but you will need a spring compressor to do the fronts.
Best of luck
- Eric
626-592-3103
Old Aug 28, 2011 | 12:33 PM
SkyWay's Avatar
Replacing shocks will only require basic tools and a spring compressor. You can usually rent them at autozone/orieleys/nappa, etc.
When you buy the exhaust pieces you need, it should come with the required gaskets. If it doesn't, try to get one at the dealer. You might be able to get away with re-using the gasket thats already on there but if at all possible, you should replace it.
Even for a novice, this job shouldn't be that hard. Hardest part is going to be removing the old shocks and compressing the spring.
Good luck and if you have any questions at all, don't hesitate to post them up!
Old Aug 28, 2011 | 01:00 PM
socialconflicts's Avatar
sometimes the nut on the front shocks are really hard to get out... try and see if someone can lend you a hand... idk buy them lunch for help? lol.
goodluck.
Old Aug 28, 2011 | 03:07 PM
AARONHL's Avatar
At least for my 2004 G, the dealership was THE ONLY place to buy the muffler to b-pipe connection ring gasket. All other connections require flat gaskets.
Old Aug 28, 2011 | 03:12 PM
BAUSauto's Avatar
Your local muffler shops will have them as well..
Old Aug 29, 2011 | 12:15 AM
AARONHL's Avatar
I've looked (in my area) and none of the muffler shops have a ring gasket over 2" diameter...we need 2.5" for the muffler.
Old Aug 29, 2011 | 03:19 AM
cmon dude.. ur a college student.. why didnt u even look at ebay?
http://www.ebay.com/sch/i.html?_from...All-Categories
slider_ua
Jul 29, 2015 04:17 PM
teamghost
Jul 28, 2015 04:52 PM
ClwMike
Jul 23, 2015 12:55 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
