Has anyone cut open a OEM 03-06 sedan muffler?
Old Sep 7, 2011 | 11:19 AM
DaveB's Avatar
Has anyone cut open a OEM 03-06 sedan muffler? I'm trying to figure out where the variable valve is inside the muffler. Thanks.
Old Sep 7, 2011 | 11:56 AM
ccc123pm's Avatar
X
^so thats what you are using it for... I cut a big "U" on the top side of the canister to remove some baffling and I dont remember seeing any valves
Old Sep 7, 2011 | 12:15 PM
DaveB's Avatar
The muffler looks great. Are you kidding about opening up one of these mufflers?
There should be a spring-loaded valve in the muffler which allows the passenger side exit pipe to flow at ~3500-4000rpms. It idle on a cold day, you see and feel only exhaust coming out the driver's side.
I've done a bit more research regarding these types of mufflers and it appears the design is solely to reduce noise at lower rpms and not to improve lower rpm power as I had orginially thought. The coupe muffler doesn't use a valve either.
I've curious about how the muffler would sound with the valve removed. I don't think it will sound like a coupe, but perhaps a bit more sporty. I've mapped out the inside of the muffler and flow paths using measuring tapes poked into the muffler pipes. I think I have a good idea on where the valve should be based on how the pipes are arranged. I'd rather cut as little as possible of the canister.
Old Sep 7, 2011 | 12:29 PM
dphillips2011's Avatar
subscribed.
do you have any pictures?
Old Sep 7, 2011 | 12:31 PM
black_gst's Avatar
interesting, i never heard about this before, now im gonna check when i leave work lol if you do cut it open post pics please
Old Sep 7, 2011 | 01:42 PM
thescreensavers's Avatar
Mr.202?
We need an X-ray machine lol
Dave Take tons of pics if you do will be interesting.
Old Sep 7, 2011 | 02:04 PM
Kuneff's Avatar
I'm not sure if this should be in the Exhaust section or not... but I am anxious to see pics.
Old Sep 7, 2011 | 02:19 PM
fobizzle's Avatar
Yeah, im in for pics and results. Also you should do a DIY for this (if you have time)
Old Sep 7, 2011 | 03:44 PM
RADIOGUY21's Avatar
subscribed!! I thought the 03-04 and 05-06 mufflers were both different?
Old Sep 7, 2011 | 04:15 PM
Mr.202?
The 03-04 are smaller but they "should" have the same internal layout
Old Sep 7, 2011 | 11:43 PM
007JD's Avatar
yea i made a thread about this 2 .. i thought i was the only 1 ...
my muffler only blows out from one side...
im not sure how it works.. cuz i rev my engine to 3 - 6k n the passenger side mufflers doesnt blow...
idk... im curious 2..
sub. in
Old Sep 8, 2011 | 12:32 AM
DaveB's Avatar
This probably won't happen until Saturday. I know there's a valve in there because I've found old thread on some Nico forum where a guy cut into one and posted pics. Of course the pics no longer show up.
Old Sep 8, 2011 | 04:29 AM
tunermaxima3000's Avatar
interestedto see the results!
Old Sep 8, 2011 | 06:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
Dave as always you da man!
sub'd for pics and more knowledge.
Old Sep 8, 2011 | 01:43 PM
SN00P's Avatar
CLUB MODERATOR
very interesting Dave ... sub'ed for pictures and more info
