Wierd Sound when shoving accelerator to the floor.
Old Oct 4, 2011 | 12:28 PM
ImNewHere's Avatar
I drive an 03 G35 automatic sedan. I was playing around on the highway with it in manual mode and put it in 5th gear doing about 70. I then shoved the accelerator pedal to the floor to see how it would react. The car seemed to rev up as if it came out of gear. Anyone know why this is?
Old Oct 4, 2011 | 12:33 PM
hurleyguys's Avatar
trans slipping?
Old Oct 4, 2011 | 12:37 PM
ImNewHere's Avatar
could be. if I'm a little easier on the gas pedal then it will go up to the governor just fine. Its only when I jam my foot on the gas does it do it. So that's definitively possible. Anything i can do about it?
Old Oct 4, 2011 | 01:42 PM
Songle6MT's Avatar
Did it come out of gear? I'm not to familiar with the auto's on these cars but most tiptronic auto tranny's will come out of the selected gear if the ratios and percentages are right for the computer to tell it too...
Old Oct 4, 2011 | 02:00 PM
Mustang5L5's Avatar
I guess the question is, was this a transmission downshift? Or the transmission slipping? How far did it rev up? To redline? Does the car accelerate? Or does it seem like it revs in nuetral?
I'm not sure how the 03 trans shift logic is, will it force a downshift if you floor it in 5th (overdrive)
Hows your trans fluid level?
Old Oct 4, 2011 | 10:09 PM
ImNewHere's Avatar
It revved up to 6k and then i let off. The car works fine otherwise. Its as if the accelerator pedal is not made to go that far down. And all of a sudden is jumps out of gear and revs up only when i push it all the way to the floor. It feels more like is jumps into neutral.
Old Oct 4, 2011 | 11:23 PM
ImNewHere's Avatar
Just tried to reproduce it and wouldn't do it again. Seems to be fine but not sure if I should look more into it or not.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
