help temp gauge running hot
Old Oct 18, 2011 | 12:20 AM
thebonafortuna's Avatar
Originally Posted by hawaii
Thanks for the input, that made a lot of sense and I hope that it is the thermostat. I guess I will find a diy and order the new thermostat.
Appreciate the kind words, but please remember I'm a novice just learning my stuff. I don't recommend ordering parts based solely on my recommendation - you really should get an independent mechanic to at least verify the problem before you start spending money.
Good luck. I hope it's something simple.
Old Oct 18, 2011 | 04:25 AM
sonicii's Avatar
^good advice, unless you are sure you know what it is, it might be better to get someone to look at it for you. You don't want to replace the thermostat and coolant only to find it is an issue with the radiator and the coolant needs to be drained again to remove it.
Originally Posted by thebonafortuna
So the coolant sits in the radiator and looks like it's full, because it's never leaving the radiator to begin
the radiator should always be full regardless. If it isn't, you have a leak somewhere!
G35Rican
Jul 31, 2024 01:37 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Gwhut?
Sep 4, 2015 11:10 PM
G35CO
Sep 4, 2015 09:27 AM
