First Gen (03-06) G35 Sedan Tips/Tricks/Facts You May Not Know
Old Jan 8, 2012 | 03:33 PM
NFSP G35's Avatar
? = 2B || !2B
^Oh is it? I couldn't remember, I had only got the first aid kit out once. I just remember laughing
Old Jan 18, 2012 | 05:40 PM
STLG35guy's Avatar
What's a PS cooler! I'm shopping for a G35 06 model and I'm debating between the coupe or sedan.
Old Feb 7, 2012 | 05:22 PM
exiledtrinib0y's Avatar
power steering cooler
Old Feb 8, 2012 | 09:58 PM
G35snewbie's Avatar
Downside of 4 window open
Thanks for the tip re hitting and holding unlock to roll down windows. Can confirm that all 4 windows rolled down when pressing and holding unlock. What I was not expecting was my bare *** in the middle of the driveway looking for a way to roll up all 4 windows! I had to get into the car, start and then roll up the windows. In reality, would not think of any reason to do what I just did in minus weather ! (as I just did). So, the ability to roll down the windows in high temps is awesome! Just does not matter when cold!!!!!
Regards
Old Feb 8, 2012 | 11:08 PM
G35snewbie's Avatar
Wink Home Link
Most are wondering after programming garage door opener and front entrance lights what the 3rd button is for on Home Link.
Cannot confirm, but perhaps this is it?
1. Press unlock. Confirm that your significant other is receptive to being unlocked.
2. Press and hold all buttons while inspecting.
3. Turn clockwise, then counterclockwise, then clockwise etc.
4. Come up for air.
5. Insure that the reccomended PSI is maintained - failure to maintain may result in a sensor default - such as a flat tire Icon. If sensor default is not detected, steps 6,7 and 8 are usually a given.
6.Press up/down and repeat over and over again.
6. A high pitched whine will be heard but fear not, as this is in sync as long as proper lubrication has been afforded.
7. More than likley, you will get breakfast in bed if all the steps above are seen through to fruition.
Man, I love all that my G35 has to give!
Old Feb 8, 2012 | 11:15 PM
NFSP G35's Avatar
? = 2B || !2B
^I don't have the home link mirror
Old Feb 9, 2012 | 12:11 AM
G35snewbie's Avatar
Thumbs up
I think you can pick up one up on the Internet for free. Not as good as OEM however!
Old Feb 25, 2012 | 12:31 PM
mrwgottaG35's Avatar
the windows will stop themselves from rolling up and come back down if you get your hand or arm stuck in-between them. didnt want to try it out on my own arm, but tested on a drunk friends arm last night lol. worked like a charm
Old Feb 25, 2012 | 01:03 PM
NFSP G35's Avatar
? = 2B || !2B
^ Well played
Old Mar 2, 2012 | 03:45 PM
g35_white's Avatar
Noticed this in 2005 G35. When we turn off A.C and the recirculation mode is off, there is still some air coming in since takes air from outside. put it on recirculation mode it stops.
Old Mar 2, 2012 | 04:02 PM
Bastone's Avatar
Not really a tip or a trick for the Gs. Every car does that.
Re-circ button pressed = fresh air vent closed
Re-circ button not pressed = fresh air vent open
Old Mar 6, 2012 | 06:58 PM
g35_white's Avatar
Do you by any chance how to get only the fan working with re-circ button pressed? In my g35, as soon as i press the re-circ button, AC comes on. But what if i just want fan and not the AC?
Old Mar 11, 2012 | 09:19 AM
GreenPenguin's Avatar
Regards
Put the key in the door and turn it left and hold it there to roll all the windows up. Turning it right and holding it rolls them all down.
Also, if you have a 6MT and lift your foot off of the clutch in first gear on an even road without giving it gas, you won't stall out. <Thats a not so fun fact...
Old Mar 26, 2012 | 03:05 AM
jbblackg35sedan's Avatar
really good info everyone , i just bought my g35 sedan and i would have probably never found out any of this things if it wasn't for all of you thanks and for sharing
Old Mar 28, 2012 | 04:10 PM
  #30
Badpreston577's Avatar
From: Fairfax County, Va (just outside Washington DC)
good tips
My neighbors were amazed that i rolled the windows down via keyless entry, nice tip. BTW although the owners manual suggest any 530 weight oil meeting specs, i suggest a full synthetic and dont go beyond 5k for the drop interval. Mothers has a great polish for those fading plastic headlamp covers and it does a great job you just need a drill and the light restoration kit.
06 G35X premium/LED white lights/Liquid Platinum paint/OEM on Z rated summer tires
