Proud new owner of a G35 sedan, but have some concerns and issues with the car!
Old Nov 6, 2011 | 06:45 PM
E38CHIC's Avatar
Hey guys,
Just wanted to introduce myself. I've been lurking this forum for a few years, but I've never actually owned a G35. I bought a beautiful 2005 G35 Sedan a few weeks ago. It's black exterior with black interior (took me a while to find one in this combination) and currently has 61k miles. It also has that cool (imo) keyless start system (didn't even know that when I bought the car since the owner didn't mention it). I actually bought the car in Florida a little less then 2 weeks ago and the car finally just arrived to my home a few days ago.
It arrived in flawless condition to my surprise and still smells brand new too.
I've been driving it for only 2 days and just about an hour ago, as I pull up to my driveway, the car shut down on me. I restarted the car and it started up, but it was hesitating to start so it didn't fire up right away. As I start the car, I get the following malfunctions: Slip, vdc off, and service engine soon. Any one know what the issue might be? I don't notice anything different in the car (i.e., no shaking or misfiring, etc..), but the only noticeable difference is the car hesitates to start up right away. Any help will be appreciated!
Old Nov 6, 2011 | 06:49 PM
faiz23's Avatar
I am heading out to run errands but search up Cam shaft position sensor should be a cheap fix.
https://g35driver.com/forums/g35-cou...y-version.html
https://g35driver.com/forums/g35-cou...on-sensor.html
http://my350z.com/forum/maintenance-...-pls-help.html
http://my350z.com/forum/maintenance-...g-and-cel.html
https://g35driver.com/forums/g-spot/...hts-all-2.html
https://g35driver.com/forums/engine-...on-sensor.html
Edit: All the lights could also mean your brake fluid is low or the pads. It might be 2 issues on hand but try to pull codes at autozone for free and report back.
Old Nov 6, 2011 | 08:43 PM
E38CHIC's Avatar
Awesome, thank you! Will run the codes tonight. Hopefully it's the cps and nothing major!
Old Nov 6, 2011 | 09:09 PM
tknobby81's Avatar
I got all those lights, changed the cam position sensor and everything was fine. 50 or 60 bucks
Old Nov 6, 2011 | 09:15 PM
pulsar1's Avatar
I had that happen at hwy speed. The car ate the air filter taking the $600 MAF with it...
Old Nov 7, 2011 | 12:32 AM
E38CHIC's Avatar
Update: didn't get a chance to run the codes yet, but just went to start car and it started up right away and the vdc and slip malfunctions are not present for now but the service engine soon light still is.
I also own a MB clk430 and I remember when the cps went out, the car always started when it was cold and barely started when it was warmed up. I'm assuming the same thing goes in this instance?
Old Nov 7, 2011 | 01:03 AM
G35SedanGrn's Avatar
check & make sure ur negative battery terminal is on tight, had the same thing happen to me & turned out it was a loose battery terminal.
Old Nov 7, 2011 | 01:11 AM
bluedevils95's Avatar
Welcome to the G community. Too bad you having troubles w/ your G. Hope you get everything worked out soon. Where in Cali are you?
Old Nov 7, 2011 | 01:22 AM
E38CHIC's Avatar
Thanks! It's a used car, so I expect there to be trouble here and there.
Bay Area.
Old Nov 7, 2011 | 05:53 AM
Blue Dream's Avatar
I drove ttrank's car solo
Get the codes read at an Autozone or other parts store and let us know what came up. That'll help pinpoint your issue.
Old Nov 7, 2011 | 12:51 PM
Mustang5L5's Avatar
Get the code read first. Don't erase it or buy parts until you do. No point guessing either
Old Nov 7, 2011 | 01:21 PM
si_driver's Avatar
Had the same issues as you. It would usually start and run when it was colder, but when it got warmer the car was hard to start and shut down a lot on me. I finally replaced the CPS and NO more problems.
Old Nov 7, 2011 | 01:38 PM
B T's Avatar
B T
Congrats on the buy and welcome to the G forums
Old Nov 7, 2011 | 06:01 PM
E38CHIC's Avatar
Just ran the code(s) and I have 5 codes which are all P0340. Looks like its the cps!
Old Nov 7, 2011 | 06:02 PM
E38CHIC's Avatar
Thanks!
