cracking sound comming from door seals,
cracking sounds comming from door seals, is there some tape i could apply to the door jams to make it go away? bmw dealership did this on my x3 and it i had 3 years of quiet ride,,,, i also would like to replace the seals on the doors, any body sells those besides dealerships?
thanks
thanks
Coming from rear doors? or both front and rear... My car creaks and drives me crazy... sound from the doors is rear only and rear deck lid... Does yours creak when going around corners when car has body roll? I would love to eliminate these sounds as well...
if it is a sedan and the creaking noise is coming from the rear doors,there was a bulletin put in place to replace the 4 rear window regulator bolts with an updated bolt part number 01125-03241
this will eliminate the noise with body roll,flex and yes it is annoying. i have replaced about a thousand of these things. they are very easy to change and you can do it yourself
hope this helps you guys...
when you remove the rear door panels,it is the 2 bolts that hold the glass to the regulator,change 1 at a time and no aadjustments or anything are needed,the nissan part number for the bolts are 01125-03241,i do not have a link to the bulletin though,sorry...
http://x.infinitihelp.com/forum/loca...yid=79&doit=Go
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
