Uh..how do you turn the heater on?
Old Dec 27, 2004 | 09:57 PM
tgenius's Avatar
I feel like such a shmuck.. I can't figure out how to turn the heater on the car on. The best I could do was turn on my seat warmer
Old Dec 27, 2004 | 10:04 PM
Britishbloke's Avatar
Hmm...let's see, you press mode, or "On"...your having a lugh right mate. It must be the time of year.
Old Dec 27, 2004 | 11:39 PM
THX723's Avatar
G Kreuzer
With the fan turned on, ya simply dial-up the temperture ... out comes hot air.
Old Dec 27, 2004 | 11:43 PM
tgenius's Avatar
I tried that, but it didn't seem to be sending out any air.
Old Dec 27, 2004 | 11:46 PM
THX723's Avatar
G Kreuzer
Do you have the 'fan on'???
Old Dec 28, 2004 | 01:06 AM
mikeee2's Avatar
I am a bit confused with my 05 g35x temperatures also. Alot of times the AC ends up turning on. I guess if you have it set to Auto or anytime when you set a specific temp in the car, the AC kicks in. Is that correct? How do I stop the Ac from turning on? Anyway when I start play with the mode button and the fan button...it gets confusing. Sometimes, I am taking too much time away from the road trying to figure out the buttons. My old accords temp. buttons are plain and simple.
Old Dec 28, 2004 | 01:27 AM
Meridian's Avatar
When you push "Auto", AC turns on automatically. Push the "AC" button to turn it off.
Old Dec 28, 2004 | 03:05 AM
xswl0931's Avatar
First, read the manual.
Second, AC doesn't mean "cold", it means "air conditioner" which basically acts as a dehumidifier (takes water out of the air).
Just leave it on auto econ or auto without the AC on (push the AC button to turn it off) and set the temp to what you want. After the engine warms up, you should start getting warm air. If not, go see the dealer.
Old Dec 28, 2004 | 04:00 AM
Klubbheads's Avatar
Just change the "MODE" to ur face and u will feel the air after ur car is warmed up.
Old Dec 28, 2004 | 05:22 AM
Msedanman's Avatar
O.F. Administrator
It won't blow until the engine coolant is up to temp also. (in Auto)
Old Dec 28, 2004 | 08:52 AM
Dudefish's Avatar
I thought the climate controls were confusing at first, but really they're not.
Mash the "AUTO ECON" button until the word "Auto A/C Econ" appears in the display. Then mash the temp up button (in 05's it's a dial) until 68 appears. Don't touch anything else. When the engine warms up, warm air starts coming out. The fan will not start blowing until the air is warm.
Some people said to mash the fan and mode buttons, I don't recommend that. Just let the system control the fan speed and the air outlets.
If you want to turn off the AC compressor, AFTER you have done what I just wrote above, mash the A/C button ONE TIME. The light should go out on the A/C button and the display will simply read "Auto"
p.s. I just like to say "mash"
Old Dec 28, 2004 | 10:37 AM
skeleton_cru's Avatar
Sedan
And you call yourself a genius...
It took me awhile to get used to the climate controls too. Don't worry though soon you will be playing that thing like a piano (and not paying attention to the road).
Old Dec 28, 2004 | 04:01 PM
mikeee2's Avatar
I find myself having to keep an eye on the AC button to shut it off from time to time. Lets say its in Auto mode. If I start pressing any of those fan buttons, I'll notice the AC turns on again. This is so annoying. Why should the AC kick in when it's still freezing cold inside the car?
Old Dec 28, 2004 | 05:22 PM
mikeee2's Avatar
Quick question. When I start the engine, the outside temperature is never accurate. It's been cold in NY so the outside temperature has been in the 20's. Everytime I start the car, it saids outside temperature is like 60+, then as the car warms up and drive it for like 5 mins, then it shows the accurate temperature. Do you guys have this problem?
Old Dec 28, 2004 | 07:00 PM
tgenius's Avatar
I have this happen to me as well, but its usually pretty close (except this week with the cold front here in south Fl)
