Noob Needs Help
Old Dec 26, 2011 | 10:23 AM
Carrottop401's Avatar
Noob Needs Help
OK, so for x-mas i received blue bat mobile overlays, led lights for interior, and 6000 k hid bulbs. I have a few questions that go along with these products...
1. I have no experience with tint film, should i have a shop do this or is it simple enough for me to do myself???
2. is there a diy for installing the led lights for interior or for installing the new headlight bulbs??
3. also, this is the set i was bought http://store.ijdmtoy.com/Infiniti-G3...nfiniti_06.htm
it says it comes with 2 front map lights, 2 side door lights, and 1 rear dome light.. the problem is is that i dont have rear dome light, so what can it be used for? or does it mean its for the back window break light???
Old Dec 26, 2011 | 10:49 AM
ArkansasG35COUPE's Avatar
My experience with tinting is: if you have not done it before, you will not be happy with the results. I attempted to tint my headlights 3 times and eventually paid a window tinter 30 bucks and they look better than anything I had done. That and I did not have all the right tools for the job. I really suggest you bite the bullet and pay someone if you want it to look perfect.
Old Dec 26, 2011 | 10:50 AM
Ohhh... and you can use the rear dome bulb for your trunk light!
Old Dec 26, 2011 | 10:52 AM
kk will take ur advice into account, i also got trunk led lights separate... i tried taking off the plastic guard on the front maps right now, but im scared im gonna snap it because it doesnt come off too easy...
Old Dec 26, 2011 | 11:02 AM
I had the same issues with mine. You have to just get a small flathead and pry it off. They will pop and crack but come out. The front corner markes on your car are the same way, I was scared to death to just yank on it, but it worked and came out. As far as the extra bulb, you may just keep it for an extra since it wont fit the license plate light either. There is a DIY for the headlights... I will see if I can find it and post for you..
Old Dec 26, 2011 | 11:05 AM
try these:
https://g35driver.com/forums/body-in...g-removal.html
https://g35driver.com/forums/v36-diy...n-install.html
You may have to paste the path in your broswer window, I didnt set them up as a hyperlink....
Old Dec 26, 2011 | 12:25 PM
artsVQ's Avatar
there is a total of 6 interior lights in a sedan... 2 front map lights, 2 bottom door lights and 2 rear map lights
Old Dec 26, 2011 | 03:22 PM
kk got the front map lights in, side markers in, rear maps,and license plate bulb in all thanks to the manual...
Xfactor
Dec 1, 2019 12:52 PM
as25656800
Aug 9, 2015 07:25 AM
-AR-
Jan 22, 2006 05:31 PM
jadaway2
Nov 6, 2005 11:08 PM
