Lost a bolt, need help
Old Jan 13, 2012 | 04:09 PM
Vectork39's Avatar
So i was installing a Black Betty grounding kit and on the last wire i dropped the bolt, however it never landed on the floor or the underbody plastic cover. no idea where it went, i even put the cover back underneath and drove around the block, and checked again, but no bolt. does anyone know what size it is or where i can get one? the surrounding bolts are not the same size (i tried already)
here are pics of the bolt im talking about
Old Jan 13, 2012 | 04:11 PM
Songle6MT's Avatar
You could contact the seller of the kit to see if they have the bolt size.
If you have a tap set you could get the size by one of those.
Just some ideas.
Old Jan 13, 2012 | 04:13 PM
Vectork39's Avatar
so the bolt holding the red wire in place is gone, missing somewhere in the engine bay
Old Jan 13, 2012 | 04:16 PM
Vectork39's Avatar
its not part of the kit, its a stock bolt
i'm going to sears and grabbing anything that looks even close to fitting
Old Jan 13, 2012 | 04:33 PM
redpearl99's Avatar
It should be an M6 (6mm) x 25mm
Old Jan 13, 2012 | 04:34 PM
.cakestar's Avatar
I wouldnt give up looking yet. Stuff like that usually turn up if you take ur time and really comb through it. I would take a rest and come back to keep looking. its probably lodged between some wires or something.
Old Jan 13, 2012 | 05:07 PM
Vectork39's Avatar
thanks redpearl that saves me a ton of time
Old Jan 13, 2012 | 05:50 PM
dukehotty's Avatar
I agree.. It didn't just disappear.. I would keep looking. It HAS to be there somewhere unless it fell off when you took that drive.
Old Jan 23, 2012 | 11:44 AM
AARONHL's Avatar
AutoZone or a Nissan Dealer will have the bolt. Just bring in a similar bolt, like the one next to it, to find the thread pitch on another nut.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
doakley92
Sep 25, 2015 12:58 PM
