p1111 code problem
Old Jan 30, 2012 | 06:21 PM
Nortex's Avatar
p1111 code problem
I installed a z tube yesterday and made the dumb mistake of touching the throttle body butterfly. Now my check engine is on and the code is a p1111 which it variable valve timing control i believe. I tried the ecu reset but no matter what I do the damn check engine light never starts blinking in step 3. Can someone help out
Old Jan 31, 2012 | 04:59 PM
Nortex's Avatar
Ithe p1111 same code as p0011
Old Jan 31, 2012 | 05:22 PM
Philly_G35's Avatar
You can disconnect your battery overnight to reset the ECU as well.
Have you checked your oil since it threw the code? One of the fixes listed for P1111 code is to change the oil. Does your car have the other symptoms listed in the link?
http://engine-codes.com/p1111_infiniti.html
Old Jan 31, 2012 | 05:29 PM
JaE35's Avatar
Moderator
G35 Sedan
disconnect your battery and pump your brakes a few times..no need to leave it over night. Engine code comes back check for vaccume leaks and/or perform the idle air reset gas pedal procedure
Old Jan 31, 2012 | 05:31 PM
Eric@TCGMiami's Avatar
I had the P0011 code thrown a few times.... I changed out the solenoid for a new one and problem solved. I didn't even reset the ECU.
Car was extra loud on the intake side when the CEL popped on.
Old Jan 31, 2012 | 07:41 PM
Nortex's Avatar
Thanks guys
Old Nov 14, 2023 | 01:54 PM
shootaJP's Avatar
6mt sport coupe w/ leather
Which solenoid did you replace. Autozone engine code check didnt tell me which side has gone bad. I took off both and cleaned them with throttle body cleaner and tested them by actuating with the battery and tested the resistance with a multimeter. Nothing seemed to be wrong but i still have P0300, P1111, and P1136 codes. I know its been like 10 years since this thread was posted but maybe somebody can help.
Old Apr 27, 2025 | 08:36 PM
nervo77's Avatar
Hey man did you ever resolve your issue? I know this is a pretty old post
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
ara777
Aug 15, 2018 04:11 AM
mike730
Jan 12, 2018 04:25 PM
saskicker32
Aug 11, 2015 02:12 PM
