Turn Signal Issue
Old Feb 7, 2012 | 08:36 AM
SkylinesTheLimit's Avatar
Turn Signal Issue
I posted this in lighting but have gotten no response. My drivers side turn signal is not on when my headlights are on, so i thought the bulb might have gone out. However, I noticed that when I put my blinker on to turn left, the turn signal will flash normally. What could be causing it to not light up normally?
Old Feb 7, 2012 | 08:44 AM
NjMatteSedan's Avatar
^ its a dual filament bulb. 1 filament is probably bad
Old Feb 7, 2012 | 08:47 AM
So then it is the bulb that I need to replace?
Old Feb 7, 2012 | 08:51 AM
JoeR45's Avatar
^ yes
Old Feb 7, 2012 | 09:01 AM
Where would be the best place to get an OEM replacement?
Old Feb 7, 2012 | 12:50 PM
01yellowr's Avatar
Any auto parts store should have them. Just make sure you get the right bulb
Old Feb 7, 2012 | 01:26 PM
Thanks guys. I really appreciate the help. Saved me some $.
Old Feb 8, 2012 | 12:46 AM
liljohnny's Avatar
I thought the 06 sedans use a 7440 in the front turn signal which is actually a single filament bulb. It does not light up unless the turn signal is engaged. it's the same on my 04......
Old Feb 8, 2012 | 02:33 AM
05_SkylineSedan's Avatar
20 Year Member
'05 and '06 is definitely a two filament bulb. Like this:
Front turn signal/Parking lamp : 12V - 21/5W
Old Feb 8, 2012 | 07:42 AM
Wrong. 05-06 stays on as parking lights
Old Feb 8, 2012 | 10:27 AM
Yep. Passengers side is always lit up. Drivers side only comes on when turning. I am going to get a new bulb today. Just wish I would have known it was the bulb sooner. I just installed 8k HIDs the other day haha. Now I gotta open up the wheel well again
Old Feb 8, 2012 | 04:43 PM
G35Papa's Avatar
You need a 7443 bulb (dual filament)
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
zcherub
Aug 30, 2015 05:04 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
