Wheels help
Old Feb 15, 2012 | 03:04 AM
leowaxx's Avatar
Post Wheels help
My G is 2003 4dr RWD with 5 spoke 17" wheels.i just bought a G35 coupe wheels 18x8 7spoke +30 offset ( ET) all around with tire 225/45 Front n 245/45 rear. N the coupe wheels doesnt come with lug nuts.
My questions are :
1. Does my oem lug nuts fit for couple wheels or i have to buy for the coupe wheel ?
2. Do i need a spacer to put the coupe wheels in my G ?
3. How many MM if i have to use the wheels spacer n what kind brand for spacer ?
Thank you.
Old Feb 15, 2012 | 07:56 AM
Blue Dream's Avatar
I drove ttrank's car solo
1. Re-use yours
2. No, they'll fit fine
3. See #2
4. When your front tires wear out replace them with 245/45 like the rears.
You're welcome.
Old Feb 15, 2012 | 10:07 AM
leowaxx's Avatar
Blue dream @ 1 more Q : does my G has TPMS ? Better i buy new Tpms or use my old one ?
Thanks again
Old Feb 15, 2012 | 02:27 PM
nghiars's Avatar
use your exisitng TPMS and transfer them to your new wheels IF you have them.
Old Feb 15, 2012 | 03:45 PM
mysoda's Avatar
1. Re-use yours
3. See #2
You're welcome.
why do you recommend putting 245 in front.
is it because with 245 in front, we can rotate the wheels?
will he need his fender rolled?
will 245 in front affect his steering?
Old Feb 15, 2012 | 04:30 PM
leowaxx's Avatar
Hey guys i found a lil wierd thing on my 2003 G35 4dr . I dont find any TPMS in my oem wheels ? When thy change my old rims with coupe rims thy dont find any TPMS at all ?
Is the 2003 G35 has TPMS in it or no ? But in my dashboard or instrumental panel i dont see any warning light or anything for the TPMS !!
Isnt wierd , is it ? When i bought the car im pretty sure that the previous owner was old ppl so thy wont do anything for customize & stock bone car.
Old Feb 15, 2012 | 04:39 PM
nghiars's Avatar
Not all vehciles came with TPMS... i beleive in 2003, it was an option at an additiaonal cost. My 2003 coupe never came with TPMS either. The lights in the car will not go off since your vehicle has never been matched with TPMS.
Old Feb 15, 2012 | 04:49 PM
Theory_EK's Avatar
Yeah do you have doggy door 03 those are the ones that wouldn't have them.
jhaddad112's Avatar
245's in the front will make your G look a little more aggressive and will allow you to rotate the wheels. No you do not need to roll fenders if you are on OEM suspension. Im currently on 18s dropped on h-techs and still have an inch or two before needing to roll the fenders.
I believe 245s all around will increase handling since it is a bigger tire.
Old Feb 15, 2012 | 04:55 PM
leowaxx's Avatar
Any body know how to DIY streering wheel tie rod end ? My G is vibrating over 60mph . Thy found my tie rod end worn out that causing the vibration . The found it after thy install the coupe wheels .
Old Feb 16, 2012 | 11:03 PM
mysoda's Avatar
thanks jhaddad112. but i think increase the front tire size to 245 will creat more under steer...
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
