need help
Old Feb 29, 2012 | 05:42 PM
007JD's Avatar
need help
for some reason i notice that my rear wheels is pointing out ward .
my rear driver wheel is pointing out the whole wheel itself..
and on the other side is normal and stragiht
i am dropped on teins coils basic
and i do have camber spc rear
i havnt done anlignment
and for some reason also
when i dropped my car
it doesnt dropp even
1 side sits a little higher then the other side
the driver rear sits higher and points out
rear passenger sits lower n sits straight
any ideas
or ways to fixs this ?
Attached Thumbnails need help-2012-02-29-17.23.53.jpg   need help-2012-02-29-17.24.15.jpg   need help-imagejpeg_2_7.jpg   need help-2011-09-30-13.46.58.jpg   need help-2012-02-26-16.59.03.jpg
Old Feb 29, 2012 | 05:48 PM
007JD's Avatar
i think you can see it more clearly in this pix that the rear wheel is point out to the left more then what its normaly should be
it should be pointing straight
Old Feb 29, 2012 | 08:27 PM
AARONHL's Avatar
Align and repost..
AARONHL's Avatar
Better hurry up or you'll be posting a WTB for a set of tires!!
Old Feb 29, 2012 | 08:54 PM
GAU-8's Avatar
Toe adjustment needed. Part of getting an alignment.
Old Feb 29, 2012 | 09:09 PM
AARONHL's Avatar
You said you have SPC rear camber installed...would that include the toe bolts? I'd recommend those if you want to save rubber.
Old Feb 29, 2012 | 09:12 PM
007JD's Avatar
yea i installed the toe bolt n did the toe bolt mod..
the tires dont have no bad tire wear ..
ive prbl had the tires since oct. n still no noticeable tire wear everything even
Old Feb 29, 2012 | 09:13 PM
007JD's Avatar
but do you guys see what im talking about ..
about the wheel is pointing outward a lil
is that fixsable tho ?
Old Feb 29, 2012 | 09:23 PM
GAU-8's Avatar
With a toe adjustment, yes.
Did you get the alignment redone after installing the arms and toe bolts?
Old Feb 29, 2012 | 10:03 PM
007JD's Avatar
no adjustment ever .. lol i know thats bad .. but i havnt been able 2 or had time but im going to .
any idea of why the un even height adjustment ?
Old Feb 29, 2012 | 10:51 PM
GAU-8's Avatar
If you just put the springs on they need a little time to settle. The only other thing that can be an obvious cause for it to be uneven is the placement of the coil springs in the spring perch. There's a specific position for them to rest in.
Old Feb 29, 2012 | 11:08 PM
AARONHL's Avatar
Did you look at the inner side of the rear tires?
Old Feb 29, 2012 | 11:12 PM
007JD's Avatar
yea .. stil good even tread wear imma take pix of it 2morr in the am
Old Feb 29, 2012 | 11:21 PM
G35Papa's Avatar
When you lower a car, your tire/rim will camber in (negative camber) and this will also cause toe to come out (toe and camber affect each other). That is why your tire is sticking out on one side. An alignment will get you back into spec. Also, having your toe off like that will wear down your tires fast (a lot faster than just having negative camber).
A lot of cars are off and it becomes more appearant when you lower a car. Since you have coils, you just need to adjust one side to match the other in height.
Old Feb 29, 2012 | 11:42 PM
007JD's Avatar
lol just to be sure if you all are understanding me . i drew a quick pix
the first pix is showing a top view of the car n the wheel
and the second pix is the a side view of the car n wheel
1 wheel pointing out ..
n 3rd pix is how i think every1 is expplaining about camber . i kno camber is what makes it slanted
like a V almost or backwards V lke this - > / \ or \ / or l l
but what im trying to say is
it looks like the front wheel when the wheel is turn slightly to the left. but in the rear..
if u do understand me and you say its the toe. then i gues imma go in 2morr to alignment shop and make sure for them 2 fixs the toe..
but hope u guys understand mee lol
