Where are you mounting amps
Old Mar 8, 2012 | 04:42 PM
twanpd4's Avatar
hey guys,
my box from zenclosures just got here cant wait to get home from work. Anyway trying to think where to mount my amp. Its not very large but since i dont have the box in my hands yet trying to get ideas of where to put it.
PICS help
thanks in advance.
Old Mar 9, 2012 | 08:07 AM
geew1z's Avatar
I built my own box and wanted a completely stealth install - so both of my amps fit inside the enclosure and the only thing you see when the trunk is open is a false back wall covered in felt, with a sub and port. This probably wont help you much since you bought an enclosure
Old Mar 9, 2012 | 02:31 PM
blazeplacid's Avatar
Took out the spare tire and made an amp mount
Bring a can of fix a flat in case
Old Mar 10, 2012 | 12:09 AM
twanpd4's Avatar
I dont believe in fix a flat. Im trying to see if i can mount it upside down. where the stock sub should be... looks like a project.
Old Mar 10, 2012 | 02:29 AM
Blue Dream's Avatar
I drove ttrank's car solo
This is how my set up will be but obviously it wouldn't work with the Zenclosures box.
Old Mar 10, 2012 | 10:56 AM
mounting an amp upside down doesn't allow the amp to cool properly.
If you have a smaller amp you are usually ok but most sub amps get hot
Old Mar 15, 2012 | 12:15 PM
twanpd4's Avatar
@blaze if always heard that was no longer true with newer amps. Not sure honestly but i was considering mounting it upside down under the shelf still may.
Old Apr 7, 2012 | 10:35 AM
RADRaze2KX's Avatar
^ all amps get hot. That's why they have heatsink-like properties, such as fins integrated into the casing.
Old Apr 9, 2012 | 05:01 PM
saywat?'s Avatar
which box did OP buy? i got the single sub box from them so theres mounting space on the left of it
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
