AC blowing warm...
AC blowing warm...
First day so far this year that was warm enough to warrant the use of the AC. But it's only blowing warm air
I've only had the car (2005 G35X with 60K miles) for 5 months or so and I know the AC was working OK during the test drive.
I can't hear the compressor clicking on at all - the clutch doesn't seem to be doing anything. I assume I would see the front of the pulley start moving when the AC was switched on (not sure about that). Either way there's no engagement noises at all.
I pulled the battery cover and checked the fuses there, but none seem related to AC. I also pulled the cover under the drivers kickpanel - the only ones that looked AC related were labelled 'blower' and they both checked fine.
Any ideas what else I should be looking at?
.I've only had the car (2005 G35X with 60K miles) for 5 months or so and I know the AC was working OK during the test drive.
Either way, I'll know soon
Yeah if there is compressor oil on any of the pipes its safe to say it has all leaked out by now. Hopefully the dealership doesn't bend you over too badly, but who knows now with environmental fees and such.
Also I forgot to mention the compressor oil is actually designed to attract moisture so if the system has been bled out there is a chance that there is now moisture in the system somewhere, normally they recommend changing the filter/dryer (different wording depending on who you talk to) as well as changing the compressor oil as well to remove all contaminants. Hope this helps.
Check behind the battery. There many fuses there. I just checked mine yesterday and do believe seeing something related to AC .............
You need to remove the buttom window trim to get to the box. The box has a black cover that you need to pull up. (assuming that it's the same on your car as my 2003 version.)
Just to put this thread to rest;
Finally got it fixed - took a while as the Nissan dealership ordered the wrong part. Twas as I suspected - when the A/C belt shredded it took out the pipe below the compressor - freon leaked out until the pressure dropped.
$550 later and I have A/C again.
Check your belts
Check your belts
Learned Hand
Oct 1, 2015 09:02 AM
master111
Sep 25, 2015 08:32 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
