60k maintenance
Old Mar 19, 2012 | 01:14 AM
ericnismo209's Avatar
60k maintenance
my car has 81k on it, bought it with 75k. call a dealer and asked about my 60k maintenance and they told me it hasnt been done.
i know i can go to a local shop and get it, but what do you think is the most important to get ?
pay for coils or get my get my long awaited maintenance?
Old Mar 19, 2012 | 02:23 AM
AARONHL's Avatar
Maintenance before suspension. You don't have to do it all right away, as it's usually an ongoing process. Unfortunately, you'll do all the recommended maintenance and then a month down the road you'll need a compression rod or wheel bearing.
Mainly just fluids at 60K, but do you feel anything else on the car that's not 100%?
Transmisson, rear dif fluids
Coolant flush
Brakes are terrible on these cars
If SES light isn't on then your good to go
Old Mar 19, 2012 | 03:56 AM
I need new brakes/rotors forsure. I'll be doing that before coils.
I was thinking an aftermarket brand but idk yet
& so only flush diff, tranny, coolant?
What about the filters? Are these so important or not so important
Everything else I can do my self
Old Mar 19, 2012 | 04:02 AM
& also what's the compression rod ? & when/why will I have a problem with it
Same with wheel bearing.
Is it cuz its a G & they were designed in a "rush"
Old Mar 19, 2012 | 12:24 PM
AARONHL's Avatar
There is an in-cabin filter, which is good for about 30k miles. Maintenance will depend on the condition of each car. I would think changing and flushing your brakes would be more important then filters. Hopefully you have already been changing your main air filter.
Common repairs include the compressions rods and wheel bearings.
Old Mar 19, 2012 | 01:21 PM
Simm0nS777's Avatar
Transmisson,
rear dif fluids
Coolant flush
Which of these 3 are the easiest to do on your own?
Old Mar 19, 2012 | 01:39 PM
BuzzLightYear's Avatar
I'd say transmission. Flush isn't recommended if ure not sure of the history of the car, so a drain and fill is prob the route u want to take. Transmission drain and fill is prob easier than a oil change. Loosen the pan bolt and let it drain. After its done draining put the bolt back on and refill with the amount that came out. Do this every 15k for two times and then every 30k it should be sufficient enough.
Old Mar 19, 2012 | 04:20 PM
wheres my main air filter at?
new to this stuff
Old Mar 19, 2012 | 08:07 PM
AARONHL's Avatar
Probably coolant, but each have their tricky parts.
Old Mar 19, 2012 | 08:09 PM
AARONHL's Avatar
new to this stuff
I should have said engine air filter. Do you know anything about the design of an engine? It's on the driver side right behind the radiator. You will have to remove a few plastic pieces to access it.
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
DRG35R
Sep 16, 2015 05:33 AM
