350z suspension on an X
Old Mar 21, 2012 | 08:57 PM
Jamal_G35x's Avatar
Hey guys, I want to put a full z suspension on my 2005 g35x but I heard that some parts don't fit. I searched for quite sometimes but couldn't find a clear answer. Is putting a full z suspension on an 05 g35x sedan possible? Thanks
Old Mar 21, 2012 | 10:05 PM
ArkansasG35COUPE's Avatar
Just wait... Someone will send you to the X thread that has about 300 pages.... I wasted like two good nights reading that and still cant answer this question. Someone let me know about the 2004 model too!
Old Mar 21, 2012 | 10:32 PM
01yellowr's Avatar
You can use the springs and I think the rear shocks but not the front struts from what I have read
Old Mar 21, 2012 | 10:34 PM
01yellowr's Avatar
Check this thread it has some info. https://g35driver.com/forums/g35-sed...uspension.html
Old Mar 21, 2012 | 11:20 PM
OKStateG35's Avatar
This is correct. Front springs, rear springs and rear shocks are interchangeable. Also, remember that any springs you put on will lower you ~.5" more than it would on a RWD.
Old Mar 21, 2012 | 11:57 PM
Jamal_G35x's Avatar
Do you think I will just be better off with full G coupe springs?
Old Mar 22, 2012 | 09:18 AM
OKStateG35's Avatar
It depends on how low you want to go. Coupe springs will put you at approx. the same height as Z springs would on a RWD.
Old Mar 22, 2012 | 09:59 AM
scouper's Avatar
Don't for get about the camber kit..... you'll that too.
Old Mar 22, 2012 | 10:20 AM
VQ35DE215's Avatar
should just consider springs for the car instead, don't have to worry about fitment issues, and they'll run you about nearly the same price. or save up and grab coilovers if you want to go lower
Old Mar 22, 2012 | 06:45 PM
Jamal_G35x's Avatar
I heard that if you put z springs or coupe springs on a g35. you do not need a camber
Old Mar 23, 2012 | 09:52 AM
scouper's Avatar
Not what I've been told by some performance shops and other G drivers.... I guess we'll see cause I just bought 350z lowering springs and cambers. Maybe becuase they are "lowering" springs and not oem is the reason.....
Old Mar 23, 2012 | 09:53 AM
JaE35's Avatar
Moderator
G35 Sedan
you won't need a camber kit for the z drop
Old Mar 23, 2012 | 07:58 PM
Gtz1stballer92's Avatar
The front struts are different but everything else will fit, I have the z springs up front with g springs in the back with z shocks
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
