From an insane 10.8mpg to a mindblowing 8.7mpg -_-
So I Changed out my Spark plugs yesterday and found that 2 of my coil packs on the driver side was nicely coated with oil, which means my valve cover or gasket has to be replaced (can someone shed some light on that, Im not to sure). But one of the main reasons why I changed the plugs was with hopes that my MPG will change A little. It shows that i averaged 10.8MPG before and now after the spark plugs were changed it went down to 8.7MPG .... has anyone had this issue? will replacing the valve covers solve it?
If i can get 14mpg i'll be happy. I'm currently dropped on H&R's and I have some negative camber all around so i need a camber kit. But that shouldn't affect my MPG so bad.
Threepoint5 (03-31-2012)
Threepoint5 (04-01-2012)
Do the calculation for MPG by:
1. Fill the tank. Note where you fill up, you'll want to return to the same pump if possible.
2. RESET your TRIP odometer on your dash.
3. Drive for however long you like. It's recommended to run close to empty so you get an accurate idea of fuel consumed across a tank.
4. Return to the same pump and fill up again. Record Gallons to 'full'. Record Miles travelled from TRIP odometer
5. Divide miles travelled (TRIP mileage) by Gallons used
6. Now you have your ACTUAL mileage. Repeat this if you like a few times to get a more accurate average mileage.
Example:
1. Full tank
2. TRIP = 0
3. Almost empty tank
4. Filled tank.
350 Miles travelled on TRIP
20 Gallons to fill up tank
5 350 / 20 = 17.5
6. 17.5 MPG
