time to replace headlights??
Old Apr 29, 2012 | 01:58 PM
Michael Jay's Avatar
3 months ago my rhs headlight flickered then went off. I turned the switch off then on again and the light remained on. Same thing recurred about 30 minutes later and I repeated the process and it stayed on...well, I've been repeating the process ever since. Last night, the same issue started with the lhs headlight. Is this an indication that I need new headlights or possibly some other issue? The owner's manual does not give one a sense of this stuff and I'd like to avoid going to the Stealership.
Old Apr 29, 2012 | 02:21 PM
Road_Warrior's Avatar
Sounds electrical. check fuses, check wires. get a multimeter if you don't already have one to check voltage levels across the light.
Old Apr 29, 2012 | 02:58 PM
JC-RH's Avatar
same exact thing happened to me. i replaced the bulb, and the problem went away.
Old Apr 29, 2012 | 03:04 PM
Many thanks, I think i'll replace the bulbs. Will need a second mortgage as I heard they're quite expensive.
Old Apr 29, 2012 | 03:07 PM
EbbAndBlow's Avatar
Check out the vendors classified part of the forum and I am sure after rummaging around in there, the lights will come out somewhat cheaper than you expected =)
Old Apr 29, 2012 | 03:12 PM
whatsnext's Avatar
i had the same problem just fixed it yesterday i replaced ballast and igniter didnt work then i replaced my hid bulbs put 8k in and fixed it i paid $30 for both the bulbs on ebay, i would start there first cheapest thing to try.
Old Apr 29, 2012 | 03:17 PM
That's awesome! My 06 sedan has xenon bulbs. Are HIDs similar?
Old Apr 29, 2012 | 03:21 PM
EbbAndBlow's Avatar
Xenon headlights are HID's =)
Old Apr 29, 2012 | 03:26 PM
whatsnext's Avatar
ya there same just go on ebay or look here at market place.
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
itschuckster
Jul 25, 2015 08:07 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
