WHAT Is This Noise?!?!?
Old May 5, 2012 | 10:34 AM
kayveeee's Avatar
I think its rubbing from the rotors by the shims, so you might have to grind it down a bit. I got the same issues but as you drive more and more seems to go away. Only time I really hear it is when I don't drive it for a while after it rains. But I'm going to get new rotors, pads, and ss brake lines soon so i'll take a look at everything closely to see what is really causing that rubbing issue before installing it.
Old May 6, 2012 | 04:38 PM
Simm0nS777's Avatar
Smile
Originally Posted by junbug
If it sounds like something is dragging (hard to tell in the video) it's probably not the pads. If you had your brakes recently done, someone probably yanked the disk with the dust shield. Put the car on ramps (or safely jack and put jack stands) and put a screw driver behind the dust shield and bend it back out enough so it doesn't rub on the disk.
Both excellent things to check.
Originally Posted by albert3029
Bro, I did my brakes last weekend. When I took it for a test drive I heard something grinding, popped out the tire and sure enough the dust shield was touching the rotor. Grabbed a screw driver pryed it back and the noise was gone.
Thank you guys! It was the dust shield rubbing against the rotor Such an easy fix.
Hopefully this thread can be helpful to someone in the future!
Old May 6, 2012 | 05:59 PM
Blue Dream's Avatar
I drove ttrank's car solo
Glad you got it figured out......
Old Aug 29, 2012 | 11:40 AM
Simm0nS777's Avatar
Can anyone do me a favor and maybe post a pic of what this dust shield looks like? I recently got my wheel bearing replaced on the front left wheel and I am now getting this noise again!!! I'd like to just do it on my own rather than taking it back to the guy who did the wheel bearing work because it's about a half an hour away.
Thanks!!
Old Sep 16, 2012 | 03:56 PM
Simm0nS777's Avatar
Thanks!!
Any help?!?! Please!
Old Sep 16, 2012 | 07:14 PM
TunerMax's Avatar
G35
simon, just go out and look, it will make sense once you start looking at it.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
