wheel almost fell off because of spacer???
Old May 9, 2012 | 07:07 PM
JustFly's Avatar
Hello,
I just recently installed 19" M45 rims with 245/40/19 tires in the front, and 255/40/19 tires in the back. Since I have an 03 sedan, these rims with these tires caused to rub on the upper control arm in the front. So I bought a set of spacers. I bought the H&R track+ DRS 5mm spacers for the front and 10mm for the back.
So last night as I was driving on the highway after I got everything installed, one of my wheels almost flew off, with the lugs coming loose. It was a scary experience and I'm trying to figure out what exactly went wrong. The studs got stripped, so I'm desperate to find a solution now. if anyone could help me out, it would be great!
Thanks!
Old May 9, 2012 | 07:11 PM
redpearl99's Avatar
did u use slip on spacers or did they have bolts built in?
Old May 9, 2012 | 07:45 PM
JustFly's Avatar
I had new studs installed that came with the spacers.
Old May 9, 2012 | 07:56 PM
bluedevils95's Avatar
Good thing that was it. If the wheel came off that wouldn't be pretty at all. Hope you get it fixed soon.
Old May 9, 2012 | 08:04 PM
faiz23's Avatar
That is why i prefer to be herrasunk or do it right and get rims with proper offset. Safety over anything else any day of the week. Please be careful and install only using torque wrench and hub centric spacers. Please inspect your work before you decide to go out there and win a darwin award.
Old May 10, 2012 | 12:31 AM
JustFly's Avatar
So these spacers turned out not to be hubcentric, although I wasn't aware that my rims required hubsentric spacers.
Old May 10, 2012 | 03:08 PM
xiaphin's Avatar
With the M45 wheels with 5mm spacer and stock wheel studs you barely get enough thread engagement with the lugnuts. Nismo 60mm wheel studs would do the trick. Thats what I bought. Easy to install.
Old May 10, 2012 | 08:58 PM
VMRWheels's Avatar
May seem like a bit of a stretch, but are you sure you have the right lug type?
Definitely look into hubcentric rings.
Old May 11, 2012 | 02:34 PM
TunerMax's Avatar
G35
Show some good pictures otherwise we cannot tell you the problem.
The only thing we could speculate:
1. Wrong spacers with incorrect hub centers for your car
2. You didn't install extended lugs
3. You overtorqued/undertorqued the wheels to one extreme or the other
4. You used the wrong lug-nuts.
Old May 11, 2012 | 06:51 PM
4DGS's Avatar
Being hub centric or not has nothing to do with this.
So you ran extended studs on both the front wheels and the rear wheels.
Which wheel "almost flew off" front or rear?
Who pressed the studs?
Old May 11, 2012 | 07:26 PM
Deezflip's Avatar
just another possibility,
too long extended lugs + closed-end lug nuts? = wheels not completely sitting
chances, this is an install error, not the spacers itself.
Old May 11, 2012 | 09:40 PM
jomamahama's Avatar
righty tighty lefty loosey
jsimonk
Dec 22, 2023 03:49 PM
tphan
Aug 31, 2015 10:45 PM
leo38cheng
Aug 17, 2015 12:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
