OK so i replaced a rack and pinion in a G35X and i reset the steering wheel angle sensor but i am getting a code for a faulty signal and the VDC wont stay on, as soon as i turn it on the traction control freaks out and brakes one of the front wheels then turns its self back off. The sensor is reading because i can see the change on a scan tool. Any recomendations?
AARONHL
close
- Join DateOct 2007
- LocationɷCONNECTICUTɷ
iTrader Positive Feedback100
iTrader Feedback Score(15)
Liked:121 Times in 113 Posts
I don't think your rack is centered.. How many steering wheel turns to full left from center? And full right? Should have 1.75 turns each way.
Or your alignment is wayyyy off, try to eye ball it to get rid of the VDC light.
when you reset the sensor, did you set it with the steering wheel in the position with the car driving straight, or just with the steering wheel set to the center position?
The 'ST angle' setting must be done with the steering wheel in whatever position is required for the car to track straight, which isn't always when the steering wheel is centred.
dont not recall if the steering wheel was set center so i will reset it with it center , and ill have to check for the turns on monday, thanks for both the replies will let u no what i find out on monday
turns out our genaric reset tool from hunter did not reset/calibrate everything right, had to take it to inifiti todo so but after that all was good
