speedometer needle light dimmed out??
Old May 14, 2012 | 06:15 PM
jayflyxx's Avatar
soo it's going out.. it dims in and out.. how can I replace or take care of it? remove the cluster?
Old May 16, 2012 | 02:22 PM
RADIOGUY21's Avatar
have you taken a look at the dimmer switch next to the VDC button and trunk release? I would start there.
Old May 16, 2012 | 05:10 PM
jayflyxx's Avatar
yah, I looked at it. It's the needle itself. If I hit the cluster the needle brightens up but dims like 3 mins later
Old May 16, 2012 | 11:16 PM
Kingd's Avatar
Yea im having the same problem, a solution to this would be great!
Old Mar 19, 2015 | 01:00 PM
Feelingice's Avatar
I have the same problem now...
It seems that there are two layers of illuminant on the needle, during the daytime both the illuminants are on; when you turn on the low beam at night, one of the needle illuminant will be off so it looks dimmed out.
Now only on layer of my needle illuminant is working...
Anyone has any suggestion?
Thx
Old Mar 19, 2015 | 04:00 PM
Mustang5L5's Avatar
It's a tiny surface mount LED that lights the cluster.
basically, soldering is going to be required, and i have no idea what the specs of the SMD are.
Someone's basically going to need to dissect their cluster to come up with an answer to this
Old Mar 19, 2015 | 07:28 PM
guitarrocker98's Avatar
You have a burnt out light.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Jnm07
Sep 5, 2015 01:16 AM
teamghost
Aug 19, 2015 04:01 PM
kinetek
Aug 3, 2015 04:25 PM
