370z 19'' wheels Install
Old May 30, 2012 | 11:56 AM
Threepoint5's Avatar
Hey folks, i'll be picking up a set of 370z wheels for my 04 sedan which is currently dropped on H&R springs. So my question is, given the ride height what will be the best setup to prevent rubbing and tire wear? I know that i'll def have to Roll my fenders but as far as Camber kit, spacers and tire size im kinda clueless Any input will be appreciated, Will post pics after installed
Old May 30, 2012 | 12:53 PM
Mr. Samster's Avatar
Most likely you will have to roll your fenders. Is it the Nismo 19s, if it is I think you need spacers to pull them out a little more.
I was wondering how is the ride on the H&R springs? Im on revised z springs with tokico blues and the ride is really ruff. I can feel all the bumps and the car bounces a lot. Do you have any pictures of the drop?
Old May 30, 2012 | 07:06 PM
pulsar1's Avatar
It will be easier to just install and correct from there I would think.
Old May 30, 2012 | 09:51 PM
It isn't the Nismo 19''s. I'm also on tokico hp blue and the ride quality on the H&Rs are excellent, there really isn't a bad thing i can say about them, not harsh at all. I actually like the ruffness but it all depends on the tolerance of the individual. I'd recommend them to anyone looking into a spring setup.
Old Jun 1, 2012 | 12:39 AM
Herbbie Hablib's Avatar
Is you car droped on sedan H&R's? if so can you post up some pics? thanks? Camber kit?
Old Jun 3, 2012 | 07:05 PM
Tunerz_Store's Avatar
The 19" wheels have the same offset & width of the s tune nismo 19" I just put on my car.
255/35/19 front and 265/35/19 rear.
Front 20mm spacer probably move up to a 25 and rear no spacer at all.
-2.0 camber set front & rear, NO rubbing except the front rubs on that small notch in the fender liner where the bracket sits behind for the bumper. Need to relocate and that will solve problem.
Old Jun 4, 2012 | 02:13 AM
Very nice!
Old Jun 4, 2012 | 02:20 AM
Rjblayz's Avatar
Looks good!
jsimonk
Dec 22, 2023 03:49 PM
Xfactor
Dec 1, 2019 12:52 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
