RPM Chart?
RPM Chart?
So I was wondering if anyone had an rpm chart that showed what rpm's are car was at in each gear at certain speeds. That would make rev matching a lot easier for me if I could just study off of a chart
Thanks
Thanks
Im not really talking about downshifting. Im talking about rev matching when you are in neutral going into a gear.
same principle. only difference is that it just depends on ur speed, and what gear you want to change into.
sounds like u needa do more driving
You can try this spreadsheet but you should enter data for YOUR car in the "yellow" axle ratio and gear ratio cells.
As of right now, my car is completely stock. Will these numbers be the exact same for me?
Once again. Thanks
Unless you want to expand the spreadsheet to include another gear, your best bet is to re-label the existing five choices to 2 - 3 - 4 - 5 - 6 and forget about first.
06g35
Feb 14, 2022 05:59 AM
