Clip unclipped on my breaks??
Old Jun 5, 2012 | 05:22 PM
GHong's Avatar
Question Clip unclipped on my breaks??
Hey folks,
TPS sensor went off the other day and took a look at the tires and noticed this clip sticking out of the brakes. What is that clip for? Is it a warning clip of some kind or should I just stick it back in it's place? Could this be the reason why my TPS sensor went off? The tires look fine (although I didn't actually get time to measure the pressures yet).
Brakes are fairly new, less than a year.
Any ideas?
Thanks!
Old Jun 5, 2012 | 05:38 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
it looks like the brake hardware shim clips, they should have nothing to do with TPS sensor
Old Jun 5, 2012 | 05:46 PM
Adro's Avatar
Ughhhhh its brakes!! not breaks!!!!!!!!!![thats in all caps btw]!!!!!!!
Old Jun 5, 2012 | 05:57 PM
rtito20's Avatar
Check all your tire pressures, they might be low. TPS (tire pressure sensor) check all tires
Old Jun 5, 2012 | 06:02 PM
GHong's Avatar
Ok, it's not the reason for setting of the TPS, but what IS it for? Is it important? Do I just put it back in it's place or did it pop out to tell me something?
Old Jun 5, 2012 | 07:06 PM
Simi_G35's Avatar
Are you using stock brake pads? If you are, you can reinstall them with that clip hooked inside the brake wear sensor. If you are using aftermarket, i don't think you can do anything about. I use Hawk pads and usually one pad has the sensor, so I install that on the outside, so it doesn't show.
Old Jun 5, 2012 | 10:44 PM
rtito20's Avatar
I see your running oem brake pads, just slide it back in the loop. That little clip is designed to open the pads after you press down the brakes.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
