Engine Noise at start up
Old Jan 15, 2005 | 08:11 PM
iafzal's Avatar
I have heard the noise from the enigne when you start the car especially when cold. I am NOT talking about the ABS charging noise that comes when the car starts moving and hits the 7mph.
I usually hear this now and then when I start and it comes with 2-3 seconds of the engine starts and normally is not loud every time and you have to pay attention to listen sometimes. It sounds kind of a grinding type noise. I came back after a 3 week vaction and when I started the car I heard the same sound but this time it was very loud, kind of scary. The car although runs the as usual and started on the first crank.
Anyone knows what the noise is and if this is really normal.
Thanks
Old Jan 15, 2005 | 08:22 PM
Msedanman's Avatar
O.F. Administrator
Thanks
I know what you mean bro, and I've heard it on my Coupe, my Sedan, and b4 these on my Maxima.
Seems to be normal for our rides-- no worries.
Old Jan 16, 2005 | 02:16 AM
Specialist23's Avatar
Thanks
that's exactly what i was asking last week. but then i also get it with my x when "slip" with my left front wheel. it's the oddest thing. i don't know if they're different sounds, but they sound very similar and seem to be coming from the same spot. what is this ABS charging noise that you speaking of?
Old Jan 16, 2005 | 05:17 AM
subrobo's Avatar
Our cars are monsters! When you have a stillen exhaust with CAI...it will be much louder. When ever i start my car, alarm of the car beside my G (underground) usually goes off. Muhahahaha drain his battery! :P so i actually press on gas hard for a few time before i leave for school~
Old Jan 16, 2005 | 08:26 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Cool The Anwswer to your question sir....
What you are hearing is the timing chain tensioner. This is a common problem with the 3.5 VQs and some higher mileage 3.0 VQs. The good news is it's not serious and it's really not a problem at all. Nissan labels this as "normal operation". The sound you are hearing is the tensioner rubbing the chain. The sound should go away within 1-2 seconds once the chain splashes some oil on the tensioner. ************************************************** ******** This is what I found out when I posed the same question some weeks ago courtesy of * DaveB *....UBCool....JBX
Attached Thumbnails Engine Noise at start up-dscf0001-2-.jpg   Engine Noise at start up-dscf0005.jpg   Engine Noise at start up-dscf0015.jpg
Old Jan 16, 2005 | 03:26 PM
kosta's Avatar
can someone post a link to the previous posts you guys are talking about
i also hear the same noise
Old Jan 16, 2005 | 04:11 PM
Msedanman's Avatar
O.F. Administrator
JBX,
Thanks for clarification on that noise. I knew it wasn't serious, just didn't know specifically what it was.
C.
Old Jan 16, 2005 | 04:17 PM
Msedanman's Avatar
O.F. Administrator
JBX just explained one noise immediately after start-up.....(timing chain rubbing on tensioner momentarily--no worries)
The other noise is explained in the owner's manual (ABS brakes) and has to do with the ABS doing a self test after startup and first driving off at low speed. (no worries)
C.
Old Jan 16, 2005 | 04:58 PM
SmoothZ's Avatar
I get that in my Z, and only when it's extremely cold (like below zero!). It goes away after about 10-15 seconds. I'm not worried. I let the car idle to get warm enough to turn on the heater. The noise has yet to affect any performance in the car.
Old Aug 4, 2005 | 03:24 PM
bythabay's Avatar
the tensioner rubbing the chain can't be great for the chain even though it is supposedly normal. Eliminate this problem altogether by using a pre-oiler (at least I have done it and I'm very VERY happy with how quiet the chain is no matter the temperature or how long the engine has been off)
I installed the pre-oiler along with a bypass system, but this is not neccessary, u can just get a stand-alone pre-oiler and there are other companies which make pre-oilers (amsoil is not the only one)
https://g35driver.com/forums/showthr...ghlight=bypass
Old Aug 4, 2005 | 08:12 PM
Lumpy's Avatar
Mine does it when the compressor turns on for the A/C when I crank the car up....at least that it what it sounds like to me.
Old Aug 4, 2005 | 09:51 PM
Andy2434's Avatar
Thanks
Check your engine oil level just to be on the safe side.
Old Jul 16, 2011 | 02:14 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
my car those same thing on cold starts
so it normal
just had a oil change at the dealer ..verything is fine
maybe go back to the dealer and leave the car over night to be on the safe side
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
joedaddy1
Jul 28, 2015 02:58 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
