Difference between 2003/04 Sedan trunk?
Old Jul 29, 2012 | 08:11 PM
sonicii's Avatar
the button was only on the 05-06 models with the round LED tails.
Attached Thumbnails Difference between 2003/04 Sedan trunk?-2005-infiniti.jpg
Old Jul 31, 2012 | 07:42 PM
KsuMax's Avatar
Originally Posted by jayflyxx
so where is the hidden button on the 04? without the doggy door, I never see one when I see an 04 so I assume it only opens via the interior button or key fob?
There isn't one. Key Fob or interior only.
Old Jul 31, 2012 | 11:11 PM
WhipWhitaker's Avatar
Originally Posted by TunerMax
I am not sure of this info, but this is what I've heard on here:
You will need to wire in a switch for the trunk, becaust the 2003.0 doesn't have one.
the 2003.5-2004 has a trunk release switch by the steering wheel.
the 2005-2006 has a almost-hidden button back by the trunk and a trunk release switch by the steering wheel
But yours has only that latch, if you install another trunk you will need to figure out some kind of trunk release.
fixed
Old Aug 1, 2012 | 04:43 PM
01yellowr's Avatar
Originally Posted by sonicii
Do you mean but release button that is on the rear bumper below the left tail light? You shouldn't need to worry about it unless you are replacing the rear bumper too.
No you dont have to switch the bumper. The "05"-"06" tails will bolt right on
Old Aug 1, 2012 | 09:30 PM
sonicii's Avatar
That's want I meant.. you don't need to worry unless you are fitting a 05-06 bumper too (which isn't necessary)
jsimonk
Dec 22, 2023 03:49 PM
tal1412
Nov 28, 2022 09:25 AM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
G35_EAZY
Jul 19, 2015 01:38 PM
