more ebay for the 05-06 sedans.. good or bad thing?
Old Jul 1, 2013 | 07:22 AM
  #121
christo's Avatar
Originally Posted by psedog
IBG, yes they are plug and play. When you swap your bulbs, make sure to remove the metal guards that are on them as those are specifically for Reflector housings not projectors. On projectors they just limit light output. As far as the 04 sedan is, I'm not sure. The only ones I could find are these
http://www.ebay.com/itm/2003-2004-In...6cb616&vxp=mtr
What metal guards are you referring to?
Old Jul 17, 2013 | 10:38 AM
  #122
054DRG35's Avatar
my temp set up until i try to retro my stocks. mine were free do to an insurance deal of someone hitting my car
Old Jul 17, 2013 | 06:11 PM
  #123
Mustang5L5's Avatar
Looks good, but the way the plate is displayed takes away from everything. I think mounting the plate correctly on the bumper would look cleaner than that
Old Jul 18, 2013 | 11:49 AM
  #124
acr's Avatar
acr
The dude probably just doesn't want to drill his bumper.
Does that bumper have a tow hook cover? If so, you should look into the Stillen no drill bracket: http://www.stillen.com/product/lic-p...v7i7v5nnirhun2
If it doesn't, I bet you could fashion a thin bracket and bolt it to the underside of the bumper.
Old Jul 23, 2013 | 05:00 AM
  #125
psedog's Avatar
Back in SD**
Left is a projector bulb. Right is a reflector bulb. Some of the aftermarket bulbs can remove that metal band.
Old Jul 25, 2013 | 09:57 AM
  #126
acr's Avatar
acr
My retrofitted eBay headlights turned out pretty good if I may say so myself.
Old Jul 28, 2013 | 08:54 PM
  #127
thejimkim's Avatar
What about the SPEC D ones?
How is their quality?
I am just worried about the flaking/cracking.
http://www.carid.com/2006-infiniti-g...-12130174.html
Old Jul 28, 2013 | 09:32 PM
  #128
JaE35's Avatar
Moderator
G35 Sedan
don't buy those..if you have an 05/06 buy the oem style ones
Old Jul 31, 2013 | 09:04 PM
  #129
thejimkim's Avatar
Hey Man I appreciate your input. I do have the 06. Is there a reason as to why I should avoid those? I am guessing they are the same ones like on Ebay? Is it because they fade or haze easily?
Old Jul 31, 2013 | 10:27 PM
  #130
Fire0nic3's Avatar
I did the same thing as you and used the the high beam location to install the morimoto projectors. But since the that area sits lower my headlight is aimed lower. I cant make the projectors aim up high because the high beam location sits too low. Even if I adjust it I cant make it match the height as if it were in the low beam location.
Old Aug 1, 2013 | 03:26 AM
  #131
psedog's Avatar
Back in SD**
This is why. This happened a few months after I installed them. My car is stored outside as we don't have Garages in Japan.
Here is what I'm talking about.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
bTanz
Oct 15, 2015 02:31 PM
